How do you get viewport lines to not appear on your plot?
Same with text.
I thought setting viewports to "hidden" would do that? And setting text to "invisible"? It doesn't work. Still appears on my printouts.
set your viewport layer to non plot in you layer manager, and do a viewport freeze for the text
Another option is to place your viewports on a separate layer. Freeze the layer before plotting. Of course, if you forget the last part you'll be kicking yourself. So, follow chelsea's advice.
