Hyperlinks Target URL (VBA) AGAIN!!!!..
Hi,
I did post this question on a previous thread but now as i'm uploading my 99.999% finished project, i thought i'd start a new fresh one..
My problem: Well, the program works (as i say) 99.999% but instead of being able to CTRL+click the inserted block once done and it whisks you merrily to the layout the hyperlink points to, it opens up windows explorer instead. But if you right-click the block, open the hyperlink editor and do nothing more than click ok as soon as it opens, try the hyperlink again and hey presto, it works as it should. So why doesn't it work straight from the program? What am i missing?
If you check the uploaded dvb file for the code, you will have to re-path where the block is inserted from of course and don't worry about when you select a layout from the list, it displays the last 3 characters, thats because all our project drawings are numbered like D01, or L05 etc..
Anyway, could someone take time to check it over and test it, because i can't understand why the link doesn't work straight from the box the way ot should..
Thanks in advance..
ModelDetailRef2.zip
Detail Reference - MSpace.dwg
  • 5 months later...
Dear Friend,
i am very much keen in using the hyperlink in Inventor. i was not able to download your file. kindly help me to resolve the problem
-premkumara alagesan
  • 1 year later...
How to insert a Hyperlink to a website in a Document, so it appears as an Icon? I can insert a link to another document from my own documents, and make it appear as an icon, but I can not do the same for a website hyperlink! I think it has something to do with embedding an object, or packaging an object but just can't work it out!
___________________
market samurai ~ marketsamurai ~ marketsamurai.com
