RyanAtNelco Posted June 19, 2009 Posted June 19, 2009 Hello, Is there anyone out there who can help me with a routine that selects all lines of a certain linetype, and displays the total length of all lines with that linetype? I was originally trying to do this with fields and a table but there are just too many lines in the particular file im working with, and i would like to be able to do this in general without setting up a field for every line. Thanks a million! Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 Is each one of the linetypes 'bylayer' or are they all set seperately or a mix of both. *side note - I used to work in woburn...* Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 As of right now they are set separately, but i was considering making new layers and setting it to "by layer". The issue with this is i would have to mess with my companies pen settings as all the standard colors are set, and my company is strict about modifying such things. Then everyone else would need the new pen settings, and as the low man on the totem pole i'd rather avoid company wide changes =). Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 where in woburn? im near the mall on gill st Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 About 2 miles down the road. I worked at skyworks inc. Of course that was about 5 years ago. Ill see what i can make for you... Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 your the man! i dont want to ask too much, but is there a way you can comment it out? i would like to learn how to make my own Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 Sure. What do you plan on doing with the numbers once you get them? You want them in excel or a text file or somewhere in the dwg? Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 excel would be perfect, it is for some takeoffs for lead quantities Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 oh i also have a bunch of line types i would like to do this for representing lead of different thicknesses, do you need the names of the line types? Quote
Lee Mac Posted June 19, 2009 Posted June 19, 2009 Just made this as a quickie : [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ltlen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ldef lt ss len[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ldef [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblnext[/color][/b] [b][color=#ff00ff]"LTYPE"[/color][/b] [b][color=BLUE]T[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lt [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] t [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Linetype <"[/color][/b] ldef [b][color=#ff00ff]">: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]""[/color][/b] lt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lt ldef[b][color=RED])[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Exit Loop[/color][/i] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]snvalid[/color][/b] lt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Linetype Name Not Valid **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"LTYPE"[/color][/b] lt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Linetype Not Found in Drawing **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"LINE"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]6[/color][/b] lt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] len [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Length[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n<< Total Length of "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sslength[/color][/b] ss[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=#ff00ff]" Lines is: "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] len [b][color=#009900]2[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n<< No Lines Found With Linetype "[/color][/b] lt [b][color=#ff00ff]" >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 LeeMac - thanks a bunch, however i only get a message saying: > there are def. continuous lines in the drawing, and i tried this with my custom linetype as well with no luck Quote
Lee Mac Posted June 19, 2009 Posted June 19, 2009 LeeMac - thanks a bunch, however i only get a message saying: > there are def. continuous lines in the drawing, and i tried this with my custom linetype as well with no luck Sorry, forgot to mention this will not work on lines set to BYLAYER - need more coding for that But just made it quickly to beat Bill to it Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 for this project, my lines are overridden to specific linetypes. this usually not the case, but my company is out of colors and i have to mess with some new colors and pen settings and get permission from the higher ups to change all that. Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 Sorry i didnt comment out what it does. Ill have to do that this weekend or on monday im at work and the day is almost over. (defun c:lte (/ drac ltype ltlst xlSheets leng pline row ss sumlen total x xlApp xlBook xlBooks xlCells xlSheet) (vl-load-com) (setq xlApp (vlax-get-or-create-object "Excel.Application") xlBooks (vlax-get-property xlApp "Workbooks") xlBook (vlax-invoke-method xlBooks "Add") xlSheets (vlax-get-property xlBook "Sheets") xlSheet (vlax-get-property xlSheets "Item" 1) xlCells (vlax-get-property xlSheet "Cells") ) (vla-put-visible xlApp :vlax-true) (vlax-put-property xlCells "Item" 1 1 "Linetype") (vlax-put-property xlCells "Item" 1 2 "Length") (setq ltlst (list (cdr (assoc 2 (tblnext "Ltype" t))))) (while (setq ltynm (tblnext "Ltype")) (setq ltlst (append (list (cdr (assoc 2 ltynm)))ltlst)) ) (setq row 2 total 0) (repeat (length ltlst) (setq ltype (car ltlst)) (if (setq ss (ssget "_X" (list (cons 0 "*LINE")(cons 6 ltype)))) (progn (setq drac -1 sumlen 0) (repeat (sslength ss) (setq pline (vlax-ename->vla-object (ssname ss (setq drac (1+ drac))))) (setq leng (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline))) (setq sumlen (+ sumlen leng))) (vlax-put-property xlCells "Item" row 1 ltype) (vlax-put-property xlCells "Item" row 2 (rtos sumlen 2 3)) (setq total (+ total sumlen)) (setq ltlst (cdr ltlst)) (setq row (+ row 1)) ))) (setq row (+ row 1)) (vlax-put-property xlCells "Item" row 1 "Total:") (vlax-put-property xlCells "Item" row 2 (rtos total 2 3)) (mapcar (function (lambda(x) (vl-catch-all-apply (function (lambda() (progn (vlax-release-object x) (setq x nil))))))) (list xlCells xlSheet xlSheets xlBook xlBooks xlApp) ) (alert "Close Excel file manually") (gc)(gc) (princ) ) Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 Sorry, forgot to mention this will not work on lines set to BYLAYER - need more coding for that But just made it quickly to beat Bill to it I too didnt make mine so that it would get linetypes that are 'bylayer' Ahahaha you sure did beat me to it... and once i saw yours i changed alot of my coding so that it wasnt as similar... (i took out my mapcars) Quote
Lee Mac Posted June 19, 2009 Posted June 19, 2009 Bill, yours will only deal with lines not set to BYLAYER yeah? Also - it will pick up all *POLYLINEs, and LINEs - I wasn't sure if the OP wanted just LINEs.. Anyway, this should deal with those *LINEs set to BYLAYER: {Some funky ss filter...} [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ltlen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ldef lt tdef ss len laylst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] laylst [b][color=#ff00ff]""[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ldef [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblnext[/color][/b] [b][color=#ff00ff]"LTYPE"[/color][/b] [b][color=BLUE]T[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lt [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] t [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Linetype <"[/color][/b] ldef [b][color=#ff00ff]">: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]""[/color][/b] lt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lt [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] ldef[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]snvalid[/color][/b] lt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Linetype Name Not Valid **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"LTYPE"[/color][/b] lt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Linetype Not Found in Drawing **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lt [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] lt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tdef [b][color=RED]([/color][/b][b][color=BLUE]tblnext[/color][/b] [b][color=#ff00ff]"LAYER"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] tdef[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] lt [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]6[/color][/b] tdef[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] laylst [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] tdef[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]44[/color][/b][b][color=RED])[/color][/b] laylst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] laylst [b][color=RED]([/color][/b][b][color=BLUE]vl-string-right-trim[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]44[/color][/b][b][color=RED])[/color][/b] laylst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"*LINE"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"<OR"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]6[/color][/b] lt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"<AND"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"<NOT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]6[/color][/b] [b][color=#ff00ff]"*"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"NOT>"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] laylst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"AND>"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]-4[/color][/b] [b][color=#ff00ff]"OR>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] len [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Length[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n<< Total Length of "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sslength[/color][/b] ss[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=#ff00ff]" Lines is: "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] len [b][color=#009900]2[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n<< No Lines Found With Linetype "[/color][/b] lt [b][color=#ff00ff]" >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 Bill, yours will only deal with lines not set to BYLAYER yeah? Also - it will pick up all *POLYLINEs, and LINEs - I wasn't sure if the OP wanted just LINEs.. Anyway, this should deal with those *LINEs set to BYLAYER: {Some funky ss filter...} Aww not fair.. I dont know how to use (cons -4) yet... you code too fast for me lol. Ill top yours sometime this weekend if i get the chance Quote
Commandobill Posted June 19, 2009 Posted June 19, 2009 Oh speaking of which is there a good post on (cons -4) ? Quote
RyanAtNelco Posted June 19, 2009 Author Posted June 19, 2009 these are great! they both do what i want pretty well i know i said earlier that i wanted it in excel, but is there a way to put it in a table in autocad too? after more thought on the subject this will be easier in the end. Lee if yours was to put the values of several line types into a table it would be absolutly perfect i would imagine a lot of people would be able to use this to save a lot of time. thanks again for your hard work guys these are really great!!! Quote
Lee Mac Posted June 19, 2009 Posted June 19, 2009 the -4 code in the ss filter is not really that hard to grasp tbh, even you should be able to get it Bill To explain it briefly, it works just like a conditional within the filter: Hence: (list (cons 0 "CIRCLE") (cons -4 "<OR") (cons 40 5) (cons 8 "0") (cons -4 "OR>")) Means, all Circles either on layer "0" or with radius 5 (or both as OR is inclusive, use XOR for non-inclusivity). Just enclose the terms in "" -4 lists, as shown. Quote
