casualmasters Posted June 19, 2009 Posted June 19, 2009 hi i need help please is thier any way that make autocad automate every dimension and level i mean i want to but dimension for each point can any lisp or any way to make my life easier Drawing1.dwg Quote
casualmasters Posted June 19, 2009 Author Posted June 19, 2009 i want autocad to automate the level of each point is thier any way to do this Quote
Lee Mac Posted June 19, 2009 Posted June 19, 2009 How about this? (defun c:lazy_dim (/ doc spc bpt ss ept) (vl-load-com) (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) (if (and (setq bpt (getpoint "\nSelect Base Point: ")) (princ "\nSelect Points...") (setq ss (ssget '((0 . "POINT"))))) (foreach pt (mapcar 'vlax-3D-point (vl-sort (mapcar (function (lambda (x) (cdr (assoc 10 (entget x))))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (function (lambda (x1 x2) (> (cadr x1) (cadr x2)))))) (if (setq ept (getpoint bPt "\nSelect Point to Dimension: ")) (progn (vla-addDimRotated spc (vlax-3D-point bPt) (vlax-3D-point ePt) pt 0)))) (princ "\n<< Incorrect Selection >>")) (princ)) Select your Base-Point, and then select all your points (red), then you just have to click at each point to dimension. Quote
casualmasters Posted June 19, 2009 Author Posted June 19, 2009 thank u mr lee but it doesn`t work for me i will tell u what do i need i want to but the levels automatically i will enter a level assume it ia -8.91m and it buts all the other levels thank u very very muck mr leee mac for help Quote
Lee Mac Posted June 19, 2009 Posted June 19, 2009 It should work. I tried it on your posted drawing and it works. Quote
casualmasters Posted June 20, 2009 Author Posted June 20, 2009 i don`t know what to say mr lee but i will ask u for one more help all i want is to make a datum and give it a level asume it will be -1.00m after that any horizontal line i choose, a lisp automatically write its level above datum Quote
Lee Mac Posted June 20, 2009 Posted June 20, 2009 i don`t know what to say mr lee but i will ask u for one more help all i want is to make a datum and give it a level asume it will be -1.00m after that any horizontal line i choose, a lisp automatically write its level above datum Did my other LISP work for you? Quote
casualmasters Posted June 20, 2009 Author Posted June 20, 2009 it works only for the file i uploaded but i tried in another one but id didn`t work Quote
Lee Mac Posted June 20, 2009 Posted June 20, 2009 I'm not sure why, I have tried it on arbitrary drawings and all seems fine - what error occurs? Quote
casualmasters Posted June 20, 2009 Author Posted June 20, 2009 mr lee mac can u tell me how to scale that drawing with scale 1:100 and plot it on A1 paper also how can i make the dimension layer scaled to the overall scale i mean by this if i draw scale 1:100 dimension scale may be .025 and for 1:200 .5 and soo on i know this question is easy but iam a beginner Quote
