Hy to everyone!!
Is anybody informed about this problem?? Removing double point(s) from drawing that is situated on the same X,Y coordinate?? I found something in this forum:
http://www.cadtutor.net/forum/showthread.php?t=29468&highlight=double+points
but didn't figure how they fix it!! Every help would be welcome...THX a lot in advance:(:roll:
And I forgot to ask one more thing, by the points is it also possible to find double txt (situated on the same position)?? thx..
how to start express tools?? I never worked with it, but I instaled it and restarted PC now.
At the command line type EXPRESSTOOLS, and it should load up the Express Tools menu. :)
Would this help at all?
http://www.theswamp.org/index.php?topic=19865.0
Everything fixed with Express tools- overkill, thx to you guys!!! First I had to uninstall ACAD and then again install it and only then Express tools worked properly...THXXXX:D:shock:8)
