Hi,
here is my Problem: I have many objects which belong together (lines, circles,...). Now I want to put them together and have just one object which then is easier to handle.
Thanks and sorry for the bad english.
Select all objects, right click your mouse, scroll down to copy with base point, click that, then pick your base point on the objects you have selected, right click again and scroll down to paste as block.
Should work for ya.
Thanks!! Works very well.
Do i have a chance to split them up again later?
Blocks can be separated into their individual components using the Explode command.
Hi,
You could also try GROUP command :)
