l still need help with my winassemblyconvert
Hello l need help l was using autodesk 3.3 winassemblyconvert cammand works but autocad Architecture 2009 says unknow command please somebody should help me thank you
right click on the door / window assemb. icon on your tool palette, there should be under "apply properties to" this should give you the options you need :)
