Bowl.Spliffson Posted June 22, 2009 Posted June 22, 2009 Hello, I'm working on a drawing of a 3d crane and I need rotate one of the booms. The problem is when I open it up in block editor it won't let me switch the ucs to the plane I need to rotate around. I am using autoCAD 2009. If anyone can help me out it would be greatly appreciated. Quote
MaxwellEdison Posted June 22, 2009 Posted June 22, 2009 Sorry, but the block editor only uses the world UCS and does not allow for switching/rotating. If you're trying to add dynamic movement to 3D solids, you'll need to make sure everything rotates on the z-axis in the WUCS. This has been one of my biggest complaints with the block editor/dynamic block design process. Quote
Bowl.Spliffson Posted June 22, 2009 Author Posted June 22, 2009 Ya that's a bit of a pain. I just used the edit block in place to get it the way I wanted to. Quote
