Just installed 2009 LT and am going through customizing. I don't see the "File, Edit, View, Insert, Tools, etc." line at the top. I also don't see the tool identifier in the toolbar as I pass the curser over them. Also, I can't seem to shrink the second command line down to one.
Can anyone please help?
Menu>workspaces>Autocad Classic
Thanks for the quick reply, but I'm not sure where I type this in to get said results. I tried the command line and that didn't work. I also typed MENU in the Info Center up on the top right, but don't see anything there about workspaces.
Use the drop down menu in the upper left corner of the program title bar. Left click the "A" icon. The menu will appear. Select>workspaces>Autocad Classic
Thank you for the help. Finally found my way around. I jumped quite a few releases, so I'm working my way through it.
Thanks again.
Been using AutoCAD for 'bout 10 years plus or minus a little.
Came off the boards.
I am too old, always use the AutoCAD Classic menu, always!
