I am using Sheet Set Manager (SSM, on command line)) to pdf drawings; from dwg to pdf.
I am using Civil 3D 2009. After I am done pdf, the pdf files a time do not come out right; for instance, there are lines that appears that were never on the original drawing, also some texts come out so dark although I put these texts on the same layer, line-weight and so on (same properties) as lighter texts.
What is the issue with extra stuff (lines, dark texts) that never exited in the original dwg file or is there something I need to change through pdf setting, is there someone out there that has the same issue, but most of all i need help solving this issue.
I have so many sheets within a project that I need to pdf with good resolution
I believe this question is more base on AutoCAD itself.
Hello out there, could you please help my question out?
