This question is for AutoCAD Architecture 2010, but I think it applies to AutoCAD. When I enter a command on command line, it doesn't work. I don't see anything on command line. However, I have to click on the command line to "activate" the command line, then I am able to enter and see a command on command line.
(Dynamic imput has been turned on)
Could you please let me know what is happening?
Thanks!
look by your cursor if dynamic input is on. Your commands should show up there.
Thanks for response.
Yes, the DYN is on.
However, when I type any command, it doesn't show up at command line, or at the cursor, and AutoCAD doesn't accept anything typed.
When I click on command line, then I am able to enter a command at command line.
Strange......:(
Any other suggestions?
  • 1 month later...
I had the same problem about the command line for resolve it I changed the font type in the options>display>font by default the font type is courier new and I selected other one diferent to this and I can visualizate againg the text in the command line and dissapear all the strange things. I hope you resolve it.:)
