sakinen Posted June 22, 2009 Posted June 22, 2009 Is it possible to make custom docking pallet which will contain summary tab from drawing properties. The idea is to insert drawing related comments in the comments field on the fly. Second possible solution is to change comments with a lisp routine. Any ideas? Quote
Lee Mac Posted June 22, 2009 Posted June 22, 2009 Excuse my ignorance, but how do you access the comments field? Quote
tzframpton Posted June 22, 2009 Posted June 22, 2009 Is it possible to make custom docking pallet which will contain summary tab from drawing properties. The idea is to insert drawing related comments in the comments field on the fly. Second possible solution is to change comments with a lisp routine. Any ideas? I've already tried it and you can't do it. Good idea though. Once the Drawing Properties fields are set in the drawing - that's it. You can't "override" them by dropping in new fields that have the same name. Quote
sakinen Posted June 23, 2009 Author Posted June 23, 2009 Excuse my ignorance, but how do you access the comments field? File, drawing properties, summary tab, comments Quote
sakinen Posted June 23, 2009 Author Posted June 23, 2009 I've already tried it and you can't do it. Good idea though. Once the Drawing Properties fields are set in the drawing - that's it. You can't "override" them by dropping in new fields that have the same name. I dont want to make new comments field, just modify existing one. Quote
tzframpton Posted June 23, 2009 Posted June 23, 2009 I dont want to make new comments field, just modify existing one. I know, still doesn't really work. Quote
