kennykramer Posted June 23, 2009 Posted June 23, 2009 I have a menu for my tablet set up especially for glass work. It was set up by an old co-worker. Now I am wanting to use it in my 2009 AutoCAD and when I try to load it the Icons on the tool bar become question marks. can I get an e-mail address to send the file and have some one look at it and see if they can help me out??? I am @ ken@jmkandassociates.com please help THANKS !!!!!! Kenny:unsure: Quote
The Buzzard Posted June 23, 2009 Posted June 23, 2009 I have a menu for my tablet set up especially for glass work. It was set up by an old co-worker. Now I am wanting to use it in my 2009 AutoCAD and when I try to load it the Icons on the tool bar become question marks. can I get an e-mail address to send the file and have some one look at it and see if they can help me out??? I am @ ken@jmkandassociates.com please helpTHANKS !!!!!! Kenny:unsure: Sure way to bring a spam attack on yourself posting email addresses. Quote
kennykramer Posted June 23, 2009 Author Posted June 23, 2009 I would have thought this site would be pretty safe from that sort of stuff and I really need some help here? Quote
kennykramer Posted June 23, 2009 Author Posted June 23, 2009 you there Buzzard??? are you sa tablet guru? Quote
Lee Mac Posted June 23, 2009 Posted June 23, 2009 I'm not sure about tablets, but are you possibly missing some bitmap files? Quote
BIGAL Posted June 24, 2009 Posted June 24, 2009 Tablets dont have icons you draw a cover sheet and sticky tape it on, was the tablet drawing made up of bitmaps hence ? marks. Are you talking about toolbars ? Quote
Car5858 Posted June 24, 2009 Posted June 24, 2009 May want to check the Tablet MFG. for up dates. Sounds like acad09 is not finding the target file. Quote
kennykramer Posted June 24, 2009 Author Posted June 24, 2009 The Menu File I Can Load But When I Do The Icons On The Screen Tool Bar And Pulldowns All Have A Question Mark Iinstead Of The Regular Icon. The Menu Has Different Location And Comands Than The One That Comes In Autocad, Had The Same Troubl With 2007 And Never Got It Figured Out Please Help Me Figure This Out If You Can Kenny Quote
Car5858 Posted June 24, 2009 Posted June 24, 2009 Maybe you need a dwg file with the icons saved as blocks. It sounds like this file was missing from the start. The menu is refering to this file and acad09 is not able to locate it. If you have the orig install disc for the tablet, try to explore the disc. and look for the dwg file/library. Quote
kennykramer Posted June 24, 2009 Author Posted June 24, 2009 Tryed To Post The Menu But It Is To Long For Me To Be Able To Post On Here, Any Suggestions?? Quote
Car5858 Posted June 24, 2009 Posted June 24, 2009 Is this the file that you were trying to load? ;;; AutoLISP routines used by the AutoCAD Standard Menu. ;;; ;;; This file is loaded automatically following the menu ACAD. (princ "\nAutoCAD menu utilities ") ;;;=== Icon Menu Functions === ;;; View -> Layout -> Tiled Viewports... (defun ai_tiledvp_chk (new) (setq m:err *error* *error* *merrmsg*) (if (= (getvar "TILEMODE") 0) (progn (princ "\n** Command not allowed in a Layout **") (princ) ) (progn (if new (menucmd "I=ACAD.IMAGE_VPORTI") (menucmd "I=IMAGE_VPORTI") ) (menucmd "I=*") ) ) (setq *error* m:err m:err nil) (princ) ) (defun ai_tiledvp (num ori / ai_tiles_g ai_tiles_cmde) (setq m:err *error* *error* *merrmsg* ai_tiles_cmde (getvar "CMDECHO") ai_tiles_g (getvar "GRIDMODE") ) (ai_undo_push) (setvar "CMDECHO" 0) (setvar "GRIDMODE" 0) (cond ((= num 1) (command "_.VPORTS" "_SI") (setvar "GRIDMODE" ai_tiles_g) ) ((< num 4) (command "_.VPORTS" "_SI") (command "_.VPORTS" num ori) (setvar "GRIDMODE" ai_tiles_g) ) ((= ori nil) (command "_.VPORTS" "_SI") (command "_.VPORTS" num) (setvar "GRIDMODE" ai_tiles_g) ) ((= ori "_L") (command "_.VPORTS" "_SI") (command "_.VPORTS" "2" "") (setvar "CVPORT" (car (cadr (vports)))) (command "_.VPORTS" "2" "") (command "_.VPORTS" "_J" "" (car (cadr (vports)))) (setvar "CVPORT" (car (cadr (vports)))) (command "_.VPORTS" "3" "_H") (setvar "GRIDMODE" ai_tiles_g) (setvar "CVPORT" (car (cadddr (vports)))) (setvar "GRIDMODE" ai_tiles_g) (setvar "CVPORT" (car (cadddr (vports)))) (setvar "GRIDMODE" ai_tiles_g) (setvar "CVPORT" (car (cadddr (vports)))) (setvar "GRIDMODE" ai_tiles_g) ) (T (command "_.VPORTS" "_SI") (command "_.VPORTS" "2" "") (command "_.VPORTS" "2" "") (setvar "CVPORT" (car (caddr (vports)))) (command "_.VPORTS" "_J" "" (car (caddr (vports)))) (setvar "CVPORT" (car (cadr (vports)))) (command "_.VPORTS" "3" "_H") (setvar "GRIDMODE" ai_tiles_g) (setvar "CVPORT" (car (cadddr (vports)))) (setvar "GRIDMODE" ai_tiles_g) (setvar "CVPORT" (car (cadddr (vports)))) (setvar "GRIDMODE" ai_tiles_g) (setvar "CVPORT" (car (cadddr (vports)))) (setvar "GRIDMODE" ai_tiles_g) ) ) (ai_undo_pop) (setq *error* m:err m:err nil) (setvar "CMDECHO" ai_tiles_cmde) (princ) ) ;;;=== General Utility Functions === ;;; ai_popmenucfg -- retrieve parameter from cfg settings ;;; <param> is a string specifiying the parameter (defun ai_popmenucfg (param) (set (read param) (getcfg (strcat "CfgData/Menu/" param))) ) ;;; ai_putmenucfg -- store parameter in cfg settings ;;; <param> is a string specifiying the parameter ;;; <cfgval> is the value for that parameter (defun ai_putmenucfg (param cfgval) (setcfg (strcat "CfgData/Menu/" param) cfgval) ) (defun *merr* (msg) (ai_sysvar nil) ;; reset system variables (setq *error* m:err m:err nil) (princ) ) (defun *merrmsg* (msg) (princ msg) (setq *error* m:err m:err nil) (princ) ) (defun ai_showedge_alert () (alert "Invisible edges will be shown after next Regeneration.") (princ) ) (defun ai_hideedge_alert () (alert "Invisible edges will be HIDDEN after next Regeneration.") (princ) ) (defun ai_viewports_alert () (princ "** Command not allowed in Model Tab **") (setq *error* m:err m:err nil) (princ) ) (defun ai_refedit_alert () (princ "\n** Command not allowed unless a reference is checked out with REFEDIT command **") (setq *error* m:err m:err nil) (princ) ) (defun ai_support_assistance_alert () (alert "Could not start Support Assistance.") (princ) ) (defun la_support_assistance_alert () (alert "Could not start Learning Assistance.") (princ) ) ;;; --- ai_sysvar ------------------------------------------ ;;; Change system variable settings and save current settings ;;; (Note: used by *merr* to restore system settings on error.) ;;; ;;; The <vars> argument is used to... ;;; restore previous settings (ai_sysvar NIL) ;;; set a single sys'var (ai_sysvar '("cmdecho" . 0)) ;;; set multiple sys'vars (ai_sysvar '(("cmdecho" . 0)("gridmode" . 0))) ;;; ;;; defun-q is needed by Visual Lisp for functions which redefine themselves. ;;; it is aliased to defun for seamless use with AutoLISP. (defun-q ai_sysvar (vars / savevar pair varname varvalue varlist) (setq varlist nil) ;; place holder for varlist (defun savevar (varname varvalue / pair) (cond ;; if new value is NIL, save current setting ((not varvalue) (setq varlist (cons (cons varname (getvar varname)) varlist ) ) ) ;; change sys'var only if it's different ((/= (getvar varname) varvalue) ;; add current setting to varlist, change setting (setq varlist (cons (cons varname (getvar varname)) varlist ) ) (setvar varname varvalue) ) (T nil) ) ) (cond ;; reset all values ((not vars) (foreach pair varlist (setq varname (car pair) varvalue (cdr pair) ) (setvar varname varvalue) ) (setq varlist nil) ) ((not (eq 'LIST (type vars))) (princ "\nAI_SYSVAR: Bad argument type.\n") ) ;; set a single system variable ((eq 'STR (type (car vars))) (savevar (car vars) (cdr vars)) ) ;; set multiple system variables ((and (eq 'LIST (type (car vars))) (eq 'STR (type (caar vars))) ) (foreach pair vars (setq varname (car pair) varvalue (cdr pair) ) (if (not (eq 'STR (type varname))) (princ "\nAI_SYSVAR: Bad argument type.\n") (savevar varname varvalue) ) ) ) (T (princ "\nAI_SYSVAR: Error in first argument.\n")) );cond ;; redefine ai_sysvar function to contain the value of varlist (setq ai_sysvar (cons (car ai_sysvar) (cons (list 'setq 'varlist (list 'quote varlist)) (cddr ai_sysvar) ) ) ) varlist ;; return the list );sysvar ;;; return point must be on an entity ;;; (defun ai_entsnap (msg osmode / entpt) (while (not entpt) (setq entpt (last (entsel msg))) ) (if osmode (setq entpt (osnap entpt osmode)) ) entpt ) ;;; ;;; These UNDO handlers are taken from ai_utils.lsp and copied here to ;;; avoid loading all of ai_utils.lsp. Command echo control has also ;;; been added so that UNDO commands aren't echoed everywhere. ;;; ;;; UNDO handlers. When UNDO ALL is enabled, Auto must be turned off and ;;; GROUP and END added as needed. ;;; (defun ai_undo_push() (ai_sysvar '("cmdecho" . 0)) (setq undo_init (getvar "undoctl")) (cond ((and (= 1 (logand undo_init 1)) ; enabled (/= 2 (logand undo_init 2)) ; not ONE (ie ALL is ON) (/= 8 (logand undo_init ) ; no GROUP active ) (command "_.undo" "_group") ) (T) ) ;; If Auto is ON, turn it off. (if (= 4 (logand 4 undo_init)) (command "_.undo" "_auto" "_off") ) (ai_sysvar NIL) ) ;;; ;;; Add an END to UNDO and return to initial state. ;;; (defun ai_undo_pop() (ai_sysvar '("cmdecho" . 0)) (cond ((and (= 1 (logand undo_init 1)) ; enabled (/= 2 (logand undo_init 2)) ; not ONE (ie ALL is ON) (/= 8 (logand undo_init ) ; no GROUP active ) (command "_.undo" "_end") ) (T) ) ;; If it has been forced off, turn it back on. (if (= 4 (logand undo_init 4)) (command "_.undo" "_auto" "_on") ) (ai_sysvar NIL) ) ;;;=== Menu Functions ====================================== (defun ai_rootmenus () (setq T_MENU 0) (menucmd "S=S") (menucmd "S=ACAD.S") (princ) ) (defun c:ai_fms ( / fmsa fmsb) (setq m:err *error* *error* *merr*) (ai_undo_push) (if (getvar "TILEMODE") (setvar "TILEMODE" 0)) (setq fmsa (vports) fmsb (nth 0 fmsa)) (if (member 1 fmsb) (if (> (length fmsa) 1) (command "_.mspace") (progn (ai_sysvar '("cmdecho" . 1)) (command "_.mview") (while (eq 1 (logand 1 (getvar "CMDACTIVE"))) (command pause) ) (ai_sysvar NIL) (command "_.mspace") ) ) ) (ai_undo_pop) (setq *error* m:err m:err nil) (princ) ) (defun ai_onoff (var) (setvar var (abs (1- (getvar var)))) (princ) ) ;;; go to paper space (defun c:ai_pspace () (ai_undo_push) (if (/= 0 (getvar "tilemode")) (command "_.tilemode" 0) ) (if (/= 1 (getvar "cvport")) (command "_.pspace") ) (ai_undo_pop) (princ) ) ;;; go to tilemode 1 (defun c:ai_tilemode1 () (ai_undo_push) (if (/= 1 (getvar "tilemode")) (command "_.tilemode" 1) ) (ai_undo_pop) (princ) ) ;;; Pop menu Draw/ Dim/ Align Text/ Centered ;;; Toolbar Dimensions/ Align Text/ Centered (defun ai_dim_cen (/ ai_sysvar ai_dim_ss) (setq ai_sysvar (getvar "cmdecho")) (setvar "cmdecho" 0) (cond ((setq ai_dim_ss (ssget "_P" '((0 . "DIMENSION")))) (command "_.dimoverride" "_dimjust" 0 "" ai_dim_ss "" "_.dimtedit" ai_dim_ss "_h") ) (T nil) ) (setvar "cmdecho" ai_sysvar) (princ) ) ;;; Shortcut menu for Dimension Text Above (defun c:ai_dim_textabove (/ ss) (ai_sysvar '("cmdecho" . 0)) (if (setq ss (ssget "_I")) (command "_.dimoverride" "_dimtad" 3 "" ss "") (if (setq ss (ssget)) (command "_.dimoverride" "_dimtad" 3 "" ss "") ) ) (ai_sysvar NIL) (princ) ) ;;; Shortcut menu for Dimension Text Center (defun c:ai_dim_textcenter (/ ss) (ai_sysvar '("cmdecho" . 0)) (if (setq ss (ssget "_I")) (command "_.dimoverride" "_dimtad" 0 "" ss "") (if (setq ss (ssget)) (command "_.dimoverride" "_dimtad" 0 "" ss "") ) ) (ai_sysvar NIL) (princ) ) ;;; Shortcut menu for Dimension Text Home (defun c:ai_dim_texthome (/ ss) (ai_sysvar '("cmdecho" . 0)) (if (setq ss (ssget "_I")) (command "_.dimedit" "_h") (if (setq ss (ssget)) (command "_.dimedit" "_h" ss) ) ) (ai_sysvar NIL) (princ) ) ;;; Screen menu item for CIRCLE TaTaTan option. ;;; first, get points on entities (defun ai_circtanstart() (setq m:err *error* *error* *merr*) (ai_sysvar (list '("cmdecho" . 0) ;; make sure _tan pick for CIRCLE gets same entity (cons "aperture" (getvar "pickbox")) ) ) ;; prompts are the same as CIRCLE/TTR command option (setq pt1 (ai_entsnap "\nEnter Tangent spec: " nil)) (setq pt2 (ai_entsnap "\nEnter second Tangent spec: " nil)) (setq pt3 (ai_entsnap "\nEnter third Tangent spec: " nil)) ) ;;; Command-line version (defun c:ai_circtan (/ pt1 pt2 pt3) (ai_circtanstart) (ai_sysvar '("osmode" . 256)) (command "_.circle" "_3p" "_tan" pt1 "_tan" pt2 "_tan" pt3) (ai_sysvar nil) (setq *error* m:err m:err nil) (princ) ) ;;; Use this if CMDNAMES == CIRCLE (defun ai_circtan (/ pt1 pt2 pt3) (ai_circtanstart) (ai_sysvar '("osmode" . 256)) (command "_3p" pt1 pt2 pt3) (ai_sysvar nil) (setq *error* m:err m:err nil) (princ) ) ;;;=== Make Object's Layer Current ============================= ;; Makes the layer of the selected object current. If there is one ;; object in the pickfirst set, it's layer is made current without ;; prompting for an object. Else a prompt is issued. (defun c:ai_molc(/ old_error end_undo old_cmdecho set1 ent undo_control) ;; Simple error handling. (defun molc_error (s) ;; Reset error handling. (if old_error (setq *error* old_error)) ;; End undo if we started one. (if (eq end_undo 1) (command "_.undo" "_end")) ;; Reset command echo (if old_cmdecho (setvar "cmdecho" old_cmdecho)) ;; Silent exit. (princ) ) ;; Save current error function. (setq old_error *error*) ;; Set error handling to molc's error function. (setq *error* molc_error) ;; Save cmdecho setting. (setq old_cmdecho (getvar "cmdecho")) ;; Turn off cmdecho (setvar "cmdecho" 0) ;; If Pickfirst is on and the selction set contains ;; one object, then use it, else prompt for one. (if (and (eq 1 (logand 1 (getvar "pickfirst"))) (setq set1 (ssget "_i")) (eq 1 (sslength set1)) ) (progn (setq ent (entget (ssname set1 0))) (sssetfirst nil nil) ) (progn (sssetfirst nil nil) (setq ent (entget (car (entsel "\nSelect object whose layer will become current: ")))) ) ) ;; Get undo setting. (setq undo_control (getvar "undoctl")) ;; Initialize flag to to end undo. (setq end_undo 0) ;; Begin Undo group if need be. (if (and (= 1 (logand 1 undo_control)) ; undo on (/= 2 (logand 2 undo_control)) ; not single undo (/= 8 (logand 8 undo_control)) ; no active group ) (progn ;; Begin a new one (command "_.undo" "_begin") ;; Set flag so that we know to end undo. (setq end_undo 1) ) ) ;; Make object's layer current. (setvar "clayer" (cdr (assoc '8 ent))) ;; Print message (princ (strcat "\n" (getvar "clayer") " is now the current layer.")) ;; Undo end (if (eq 1 end_undo) (command "_.undo" "_end") ) ;; Turn on cmdecho (setvar "cmdecho" old_cmdecho) ;; Reset error function. (setq *error* old_error) ;; Silent exit. (princ) ) ;;; Shortcut menu Deselect All item. (defun ai_deselect () (if (= (getvar "cmdecho") 0) ;start if (command "_.select" "_r" "_all" "") (progn ;start progn for cmdecho 1 (setvar "cmdecho" 0) (command "_.select" "_r" "_all" "") (setvar "cmdecho" 1) ) ;end progn for cmdecho 1 ) ;end if (terpri) (prompt "Everything has been deselected") (princ) ) ;;; ;;; Enable Draworder to be called from a menu ;;; Checks for Pickfirst selected objects ;;; (defun ai_draworder (option / ss ) (setq m:err *error* *error* *merr*) (ai_sysvar '("cmdecho" . 0)) (if (setq ss (ssget "_I")) (command "_.draworder" option) (if (setq ss (ssget)) (command "_.draworder" ss "" option) ) ) (ai_sysvar NIL) (setq *error* m:err m:err nil) (princ) ) (defun c:vlisp () (if (/= nil c:vlide) (c:vlide)) ) (princ "loaded.") (princ) If it is This is a lisp, and I am still learning about the programing of lisp functions. perhaps this should be in the lisp section:unsure: Quote
Car5858 Posted June 24, 2009 Posted June 24, 2009 Thanks Buzzard, knew I did something wrong. Fixed now. Quote
kennykramer Posted June 25, 2009 Author Posted June 25, 2009 Where Can I Find The Icon Bmp Files In Cad 2009 ??? Quote
The Buzzard Posted June 25, 2009 Posted June 25, 2009 Where Can I Find The Icon Bmp Files In Cad 2009 ??? Kenny, If you still have your old installation of CAD, Your best bet is to import your settings as I once pointed out to you before. See attached link: http://www.cadtutor.net/forum/showpost.php?p=230614&postcount=15 The icon directory for 2009 is located under Documents and Settings\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Support\Icons. But you may be disappointed to find this directory empty. If you do not have your old installation available, Then maybe do a new inatall of 2009 with a detailed configuration including your tablet. Not an ideal choice of course. Also not sure if you can do a repair installation the way they use to do on the older versions although not sure if that would resolve your problem just the same. Finally try Autodesk and if there is anything on the subject. You got some research to do. Quote
kennykramer Posted June 26, 2009 Author Posted June 26, 2009 Buzzard I Tryed Tha Cui Import Thing But There Was Still No Glass Menu Under The Legacy What Could I Be Doing Wrong Please Help Further Thanks Kenny Quote
The Buzzard Posted June 26, 2009 Posted June 26, 2009 Buzzard I Tryed Tha Cui Import Thing But There Was Still No Glass Menu Under The Legacy What Could I Be Doing Wrong Please Help Further Thanks Kenny Kenny, Honestly it has been a while for me since I last used a tablet. Since the newer versions of CAD it seems things have gotton more complicated. At this stage I do not know what to tell you. Have you posted in the Hardware section of the forum? You may be able to get your answer there. Sorry Kenny but I am all out of answers. The Buzzard Quote
kennykramer Posted June 26, 2009 Author Posted June 26, 2009 Buzzard Thanks So Much Ill Keep Looking Maybe Some One Out There Can Help Me Figure This Out Again Thanks For Trying Kenny Quote
The Buzzard Posted June 26, 2009 Posted June 26, 2009 Buzzard Thanks So Much Ill Keep Looking Maybe Some One Out There Can Help Me Figure This Out Again Thanks For Trying Kenny Again sorry Kenny, I wish I could have been more help. But there are sections on the forum that deal with these issues. I am sure if you are in the right place someone will be ready to help you better. Good Luck Quote
andrew361 Posted June 26, 2009 Posted June 26, 2009 was wondering if anyone would know how to create a lisp command to enter "1" for a certain block "2" for a different block and so on. I somewhat created the lisp file but stops at how many hots per circuit, any suggestions. thanks (defun c:HRtest () (command "-layer" "s" "ee-wire" "") (command "LINE" pause pause "") (command "insert" "z:/details/nrg/elec/blocks/arrowh" pause "1" "1" pause) (ghn(- (getint "\n\Number of hots per Circuit "))) (if 1 (command "insert" "z:/details/nrg/elec/blocks/_elec_ghn" pause "1" "1" pause) ) (if 2 (command "insert" "z:/details/nrg/elec/blocks/_elec_ghhn" pause "1" "1" pause) ) (command "-layer" "s" "ee-text" "") (command "mtext") out (close out) ) Quote
The Buzzard Posted June 26, 2009 Posted June 26, 2009 was wondering if anyone would know how to create a lisp command to enter "1" for a certain block "2" for a different block and so on. I somewhat created the lisp file but stops at how many hots per circuit, any suggestions. thanks (defun c:HRtest () (command "-layer" "s" "ee-wire" "") (command "LINE" pause pause "") (command "insert" "z:/details/nrg/elec/blocks/arrowh" pause "1" "1" pause) (ghn(- (getint "\n\Number of hots per Circuit "))) (if 1 (command "insert" "z:/details/nrg/elec/blocks/_elec_ghn" pause "1" "1" pause) ) (if 2 (command "insert" "z:/details/nrg/elec/blocks/_elec_ghhn" pause "1" "1" pause) ) (command "-layer" "s" "ee-text" "") (command "mtext") out (close out) ) Please start a new thread with the subject in question. You will get more help that way. This is someone elses thread with a different subject. Quote
