pinetree56 Posted June 24, 2009 Posted June 24, 2009 How can you draw a leader line with two arrowheads? Or how can you draw a dimension line with no text. I work for a land surveying firm and we are new to AutoCAD. We have 2010 and mostly use microstation. Quote
SPARKY77 Posted June 24, 2009 Posted June 24, 2009 just copy the leader arrow draw the dimension, then go into the properties and put a space in the text override. Quote
Zorg Posted June 25, 2009 Posted June 25, 2009 mleader should work? multi leader should be under your express tools Z Quote
Tiger Posted June 25, 2009 Posted June 25, 2009 Multileader can have two arrowheads yes, I usually add the second (or more) one afterwards by mirking it, rightclick and choose Add Leader. pst. Mulitleader is under Dimension nowadays :wink: Quote
RFRUSSO Posted June 25, 2009 Posted June 25, 2009 If you are using the quick leader you can create a second leader by selecting the leader, and then click on the grip point at the leader head and type C and hit enter. That will make a copy of the leader on top of it's self. Quote
