Generally I dont use Initget but on my latest lisp i decided to give it a shot. What I found is if I wanted to use it twice in a lisp for different reasons I cannot update it. Is there a way to overwrite an existing initget or should i try another method?
Initget will only hold for the next "getXXX" function, its effects will not carry through after that particular "getXXX" function has executed.
Ok so your are correct. Whats strange is when i wrote it directly into the autocad command line it didnt clear the initget... Thanks again.
The help file on initget explains a lot :wink:
