Hello, im new to autocad and lisp. I have been scouring the net for 2 weeks in an attempt to find code to modify a lisp i am using with no luck.
I have modified the original BOMtoCSV.lisp code to do almost all of what i need. I am trying to extract text from a table in a drawing, separate the fields by comma's. then add two other text fields to the same row.
eg: COL1 COL2 COL3
Row1: XXX XXX XXX
the text is dumped as XXX,XXX,XXX but i also want to add two other fields, that i was thinking would need to be added as coordinates. also separated by comma's and copied for each row of the table.
such as (ssget "_W" (list 16.8 10.3)(list 18.9 5.0) '((0 . "TEXT"))))
I dont usually post because i know how annoying newbie requests are, but i have been unable to find much for modifying the layout of extracted text before it is written.
If its possible, any help would be greatly appreciated. Thanks.
I have added the code below
;; BOM to CSV; A program to create a csv file from a text based table in AutoCAD
;; Author: Doug Barnes
;; Company: Grantek Systems Integration
(defun Cleanup_Text ()
;; find all the text with no content and erase them
(setq nil_text
(ssget "x"
'((-4 . "<and") (0 . "TEXT") (1 . "") (-4 . "and>"))
;; search for text with no content
(if nil_text
(command "erase" nil_text "")
;; erase text with no content
;; end cleanup_text defun
(defun Gather_Text (/ sel2 ct)
(setq Text_SS (ssget "_W" (list 16.8 10.3)(list 18.9 5.0) '((0 . "TEXT"))))
(setq sel2 (ssget "_W" (list 16.8 16.6)(list 25.8 11.0) '((0 . "TEXT"))))
(setq ct 0)
;set counter to zero
(repeat (sslength sel2)
;get the number of items in selection set 2
;and loop that number of times
(ssadd (ssname sel2 ct) Text_SS)
;get the name of the entity from selection set 2
;by using the counter index number and add it to
;selection set 1
(setq ct (1+ ct))
;increment the counter by 1
);end repeat
;; create a selection set for all text selected by the user.
;; end Gather_Text defun
(defun MakeList_X_Y_Text (Text_SS)
;; Make a list of x-coords, y-coords and text
(setq MakeList_cnt 0)
(repeat (sslength Text_SS)
(setq X_cord
(if (= (cdr (assoc 72 (entget (ssname Text_SS MakeList_cnt))))
0
;; check for the text's justification
(cadr (assoc 10 (entget (ssname Text_SS MakeList_cnt))))
;; if left justified use first alignment point
(cadr (assoc 11 (entget (ssname Text_SS MakeList_cnt))))
;; else use second alignment point
;;end if
;;end Setq
(setq y_cord
0
(caddr (assoc 10 (entget (ssname Text_SS MakeList_cnt))))
(caddr (assoc 11 (entget (ssname Text_SS MakeList_cnt))))
;;end if
(setq List_X_Y_Text
(append
List_X_Y_Text
(list
(list
(cons "X coord"
X_cord
(cons "Y coord" y_cord)
(cons "Text"
(cdr (assoc 1 (entget (ssname Text_SS MakeList_cnt))))
;;make assocation list of x, y and text dotted pairs
(setq MakeList_cnt (1+ MakeList_cnt))
;; index to next entity
;;repeat
;;end MakeList_X_Y_Text defun
(defun Sort_by_X (List_X_Y_Text)
;; re-order list from left to right
(setq X_List
(vl-sort
List_X_Y_Text
(FUNCTION (LAMBDA (E1 E2) (< (cdar E1) (cdar E2))))
;; end Sort_by_X defun
(defun Sort_by_Y (List_X_Y_Text_Col)
;; re-order list from top to bottom
(setq Y_List
(vl-sort
List_X_Y_Text_Col
(FUNCTION (LAMBDA (E1 E2) (> (cdadr E1) (cdadr E2))))
;; end Sort_by_Y defun
(defun Get_Columns (X_List)
;; determine the number of columns text
(setq Column_Qty 1
X_List_cnt 0
(repeat (length X_List)
;; add a column number to List_X_Y_Text
(setq List_X_Y_Text_Col
(append List_X_Y_Text_Col
(list (list
(assoc "X coord" (nth X_List_cnt X_List))
(assoc "Y coord" (nth X_List_cnt X_List))
(assoc "Text" (nth X_List_cnt X_List))
(cons "Column" Column_Qty)
(if (/= (nth (+ X_List_cnt 1) X_List) nil)
;; Check for end of list
(if
(- (cdr (car (nth (+ X_List_cnt 1) X_List))) Line_Tolerance)
(cdr (car (nth X_List_cnt X_List)))
;; if the X Coord of the next text is out of tolerance with the current text then increase the column count
(setq Column_Qty (1+ Column_Qty))
(setq X_List_cnt (1+ X_List_cnt))
;; index list position
;; end repeat
;; end Get_Columns defun
(defun Get_Rows (Y_List)
;; determine the number of rows of text
(setq Row_Qty 1
Y_List_cnt
0
(repeat (length Y_List)
;; add a row number to List_X_Y_Text_Col
(setq List_All
(append
List_All
(list (list ;; make a list of x, y, text, column and row
(assoc "X coord" (nth Y_List_cnt Y_List))
(assoc "Y coord" (nth Y_List_cnt Y_List))
(assoc "Text" (nth Y_List_cnt Y_List))
(assoc "Column" (nth Y_List_cnt Y_List))
(cons "Row" Row_Qty)
(if (/= (nth (+ Y_List_cnt 1) Y_List) nil)
(if (<= (cdr (cadr (nth (+ Y_List_cnt 1) Y_List)))
(- (cdr (cadr (nth Y_List_cnt Y_List))) Line_Tolerance)
;; if the Y Coord of the next text is out of tolerance with the current text then increase the row count
(setq Row_Qty (1+ Row_Qty))
;; end if
;;end progn
;; end if
(setq Y_List_cnt (1+ Y_List_cnt))
;; end repeat
;; end Get_Rows defun
(defun Write_BOM_to_CSV ()
(setq Position 0)
(setq Path (getvar "dwgprefix"))
;; Obtain the file path of the drawing
(setq Dwg_Name (substr (getvar "dwgname")
1
(- (strlen (getvar "dwgname")) 4)
;; remove the .dwg from the file name
(setq BOM_CSV_File (open (strcat Path Dwg_Name " WELD.txt") "a"))
;; Open a CSV file for ammending
(while (/= (nth Position List_All) nil)
(setq Current_Row (cddr (nth Position List_All)))
;; setup to gather all of the same row text
(setq Next_Row (cddr (nth (+ Position 1) List_All)))
;; setup to check end of row
(while (= (cdr (assoc "Row" Current_Row))
(cdr (assoc "Row" Next_Row))
;; loop for all the same row
(setq Text_Column
(append Text_Column
(list (list (cdr (assoc "Text" Current_Row))
(cdr (assoc "Column" Current_Row))
;; create a list of text and column only
(setq Position (1+ Position))
;; index position in list
;; end if
(setq Text_Column
(append Text_Column
;; append Text_Column with the last text in the current row
(setq Text_Column
(vl-sort
Text_Column
(FUNCTION (LAMBDA (E1 E2) (< (cadr E1) (cadr E2))))
;; Sort list by Column number (left to right)
(setq Column_Qty_Count
1
Write_Row ""
Column_List_Position
0
(repeat Column_Qty
;; repeat for the maximum number of columns
(if (= (cadr (nth Column_List_Position Text_Column))
Column_Qty_Count
;; check the position of the current text's postion with the column count
(progn ;; if equal string together the cuurent text and a comma
(setq
Write_Row (strcat
Write_Row
(car (nth Column_List_Position Text_Column))
(setq Column_List_Position (1+ Column_List_Position))
;; index position
;; end progn
;; if not equal string together previous text and a comma
(setq Write_Row (strcat Write_Row ","))
;; end if
(setq Column_Qty_Count (1+ Column_Qty_Count))
;; index the column count
;; end repeat
;;(print Write_Row)
(write-line Write_Row BOM_CSV_File)
;; write the current row to the csv file
(setq Text_Column nil)
;; reset for next row
;; end while
(close BOM_CSV_File)
;; close the csv file
;; end Write_BOM_to_CSV defun
;; Create a CSV file from a text based Bill of Materials in AutoCAD
(defun c:weld (/ X_List Y_List
Text_Column List_X_Y_Text List_X_Y_Text_Col
List_All
(Cleanup_Text)
(Gather_Text)
(MakeList_X_Y_Text Text_SS)
(Sort_by_X List_X_Y_Text)
(setq Text_Height (cdr (assoc 40 (entget (ssname Text_SS 0)))))
;; get the text height used
(setq Line_Tolerance (+ Text_Height (* Text_Height 0.1)))
;; set up a line spacing tolerance
(Get_Columns X_List)
(Sort_by_Y List_X_Y_Text_Col)
(Get_Rows Y_List)
(Write_BOM_to_CSV)
;; end defun
I was attempting to add a simple text string at the end of the last entry for each row just before it is printed to the CSV file. but nothing worked.
if there is a way to add a text string or another variable into each row after the last comma, i think it would need to be added into this small piece of the HUGE code.
 (setq Position 0)
   1
     (setq Text_Column
     (append Text_Column
   ;; end if
   (setq Text_Column
   (append Text_Column
   (setq Text_Column
   (vl-sort
     Text_Column
   1
  Write_Row ""
   0
   (repeat Column_Qty
     Column_Qty_Count
       (setq
  Write_Row (strcat
       Write_Row
       ;; index position
;; end progn
     ;; end if
   ;; end repeat
   ;;(print Write_Row)
 ;; end while
