Hi Guys,
Just wondering if anyone else has the same issue sometimes that when they try to publish some drawings from sheet set manager only some drawings print and the rest come up with the error : "ERROR: Layout Not Found".
I know that one way to fix this problem is to copy everything either into a new layout or a new drawing, but I was wondering if anyone out there had a better solution to my problem.
Cheers:)
could be that some of ur drawings r in model space n not a layout, if so then the only option is to cut n paste as u say.
My drawings aren't in model space, so that can't be the problem.
But I did find that removing from them from the sheet set manager and then importing them back in again worked.
I'm just worried that this wont always work.:geek:
In your page setup manager do you have layout selected.
If so I would change this to extents.
Ok, mine were set to layout.
Thanks for that tip. Cheers
