Hi All,
sorry if this has been posted before but wasnt sure what to put in the subject field to track down an answer.
we have not long ago upgraded to 2010. it has this annoying little habit.
with our 2009 if an xref is locked it would shade. when you unlock it would lighten up. it was quite handy.
now in 2010 wether the xref is locked or not it is always shaded and the shading is sum what darker than it was in 2009 version.
*drum roll* here comes the question -
is there some tool palette or commands that can be used to get 2010 to behave like our 2009 version did?
cheers
ok found one.
tools > options > display tab >
bottom right corner FADE CONTROL under it is xref display.
so this made the xref a bit brighter and easier to see.
now the other issue. when locking the xref layer would like the xref to fade to a slightly darker colour. anyone know where that control is?
