au-s Posted June 25, 2009 Posted June 25, 2009 That code works in ACAD2008 but stops in ADT2008 when I create leader and trying to write text. Please, any ideas?? (defun LDR:SetLayer (skala) (setq lagerDel1 "A-------D3-------") (cond ((= skala "1") (setq lagernamn (strcat lagerDel1 "A"))) ((= skala "2") (setq lagernamn (strcat lagerDel1 "J"))) ((= skala "5") (setq lagernamn (strcat lagerDel1 "B"))) ((= skala "10") (setq lagernamn (strcat lagerDel1 "C"))) ((= skala "20") (setq lagernamn (strcat lagerDel1 "D"))) ((= skala "50") (setq lagernamn (strcat lagerDel1 "E"))) ((= skala "100") (setq lagernamn (strcat lagerDel1 "F"))) ((= skala "200") (setq lagernamn (strcat lagerDel1 "G"))) ((= skala "400") (setq lagernamn (strcat lagerDel1 "K"))) ((= skala "500") (setq lagernamn (strcat lagerDel1 "H"))) ) (if (tblsearch "layer" lagernamn) (command "_layer" "s" lagernamn "") (command "_layer" "m" lagernamn "c" 1 "" "") ) ) (defun LDR:SkapaLDRstilPILText () (setq dimtyp "PilText-") (setq DimNamnPiltext (strcat "AIX_" dimtyp skala)) (IF (tblsearch "dimstyle" DimNamnPiltext) (command "dimstyle" "r" DimNamnPiltext) (progn (setvar "dimtxt" 3) (setvar "DIMCLRD" 1) (setvar "textsize" (* 3.0 (atoi skala))) (setvar "dimasz" 3.25) (setvar "dimtxsty" "AIX_ISO") (setvar "dimgap" 1.5) (setvar "dimldrblk" "_Open90") (setvar "dimscale" (atoi skala)) (command "_dimstyle" "s" DimNamnPiltext) (setvar "DIMCLRT" 1) (setvar "DIMCLRD" 1) ) ) ) (defun c:AIX:LDRPil_Text (/ skala p1 p2 p3 oldlay) (setq oldlay (getvar "clayer")) (Load "K:\\CAD\\AIX-meny-2008\\Lisp\\alla\\AIX_PopupSkala.lsp") (PopupSkala) (LDR:SetLager skala) (LDR:SetLager skala) (IF (NOT (TBLSEARCH "Style" "AIX_ISO")) (AIX:ISO) ) (LDR:SkapaLDRstilPilText) (setq p1 (getpoint "\nStart Point: ") p2 (getpoint p1 "\nSecond point: ") ) (grdraw p1 p2 1 1) (setq p3 (getpoint p2 "\nTextplacement: ")) (command "_leader" p1 p2 p3 "" "" "" "") (setvar "clayer" oldlay) (redraw) ) Quote
au-s Posted June 26, 2009 Author Posted June 26, 2009 much simplier (defun c:ldr (/ p1 p2 p3 oldlay) (setq oldlay (getvar "clayer")) (setq p1 (getpoint "\nStart Point: ") p2 (getpoint p1 "\nSecond point: ") ) (grdraw p1 p2 1 1) (setq p3 (getpoint p2 "\nText Placement: ")) (command "_leader" p1 p2 p3 "" "" "" "") (setvar "clayer" oldlay) (redraw) ) breaks in ADT?? why? Quote
jammie Posted June 26, 2009 Posted June 26, 2009 Are the prompts for the leader the same in ADT as ACAD08? Sometimes OSNAPS can be a problem when using command functions in Lisp (defun c:ldr (/ p1 p2 p3 oldlay os) (setq oldlay (getvar "clayer") os (getvar "osmode")) (setq p1 (getpoint "\nStart Point: ") p2 (getpoint p1 "\nSecond point: ") ) (grdraw p1 p2 1 1) (setq p3 (getpoint p2 "\nText Placement: ")) (setvar "osmode" 0) (command "_leader" p1 p2 p3 "" "" "" "") (setvar "clayer" oldlay) (setvar "osmode" os) (redraw) ) Quote
au-s Posted June 26, 2009 Author Posted June 26, 2009 You maybe right. if they are different, that's bad. I need to have that lisp working on both programms, ACAD2008 and ADT2008. Thanx for the suggestion, it did not solve the problem... I'm getting Start Point: Second point: Text Placement: nil So it breaks after Text placement Quote
au-s Posted June 26, 2009 Author Posted June 26, 2009 Can you not entmake the leader? (entmake (list (cons 0 "LEADER") ) ) (defun c:ldr (/ p1 p2 p3 oldlay os) (setq oldlay (getvar "clayer") os (getvar "osmode")) (setq leader (entlast) elist (entget leader)) (setq p1 (getpoint "\nStart Point: ") p2 (getpoint p1 "\nSecond point: ") ) (grdraw p1 p2 1 1) (setq p3 (getpoint p2 "\nText Placement: ")) (setvar "osmode" 0) (command "_leader" leader p1 p2 p3 "" "" "" "") (setvar "clayer" oldlay) (setvar "osmode" os) (redraw) ) is that a good clean looking code? works at least for now. Quote
Lee Mac Posted June 26, 2009 Posted June 26, 2009 I think theres a better way to do it. - check the coding used in this> http://www.theswamp.org/index.php?topic=29245.0 [ or just use that ] Quote
au-s Posted June 29, 2009 Author Posted June 29, 2009 I think theres a better way to do it. - check the coding used in this> http://www.theswamp.org/index.php?topic=29245.0 [ or just use that ] Yeah, I tried that but it doesnt really work. Lisp works but it is made like a leader and mtext seperate. It only chooses text to be on one side. If I grab the text and move it the "leader" doesnt follow as in real acad leader. The above breaks as well ... Quote
