maxwku Posted June 25, 2009 Posted June 25, 2009 I have attached a drawing (attach image) to my AutoCAD. But now when I send the drawing to some one else the attached dwg does not follow. I understand there is a way I can bind things to the cad drawing, does any one know how to do this. I have tried to go to Insert-External References and then left click on the file, but bind is not one of the options. Does anyone have any suggestions (other then sending the picture with the AutoCAD file)? Quote
Cad64 Posted June 26, 2009 Posted June 26, 2009 Use the ETRANSMIT command when sending drawings. Hit F1 and check your Autocad Help files for information. Quote
PS_Port Posted June 26, 2009 Posted June 26, 2009 As Cad64 said The ETRANSMIT command is good option. It zips every file associated with your drawing (.cbt, .shx , images, xrefs.), you can select what files to batch zip, in the etransmit dialog. Quote
