ashish_mohekar Posted June 29, 2009 Posted June 29, 2009 My Requirement is : I want to select the line OR PolyLine; If it is Condition 1 : If it is line Or Polyline ;Tell it is line or Polyline ;; Then Joint or Close loop, After joining tel me the final result : " it is open Loop & Its Length is "VALUE" ." Condition 2 : If it is Poly Line or Line :Tell it is line or Polyline ;; Then Joint or Close loop, After joining tell me the final result " It is open OR Close Loop with Length OR Perimeter which is applicable for same. " I want req. the output it text which is inser into drawing. Select the object : Pick the point where u have to isert the text. : Object is LINE OR POLYLINE ; IT it is open or Close loop ; with Length Or Perimeter Value. Please send the Lisp Code for above requirement.. Quote
alanjt Posted June 29, 2009 Posted June 29, 2009 Please send the Lisp Code for above requirement.. wow, you have absolutely no interest in figuring out any of this on your own. Quote
Lee Mac Posted June 29, 2009 Posted June 29, 2009 Please send the Lisp Code for above requirement.. And what exactly do we get out of this? Quote
