  • Replies 31
  • Lee Mac
    15
  • asos2000
    10
  • The Buzzard
    2
  • stevesfr
    2
Lee
The same
I just tested it and it seems to function correctly for me - what is happening for you? Does it not count anything? Does it error?
Works fine here ! :)
It seems to yield correct results, looking at your drawing Asos, the LISP will count every instance of the selected text strings in the drawing. You had 10 copies of every string that you selected.
I selected the text in each rectangle separately
The lisp gives me the same result
Yes, that is correct, the LISP counts every instance of each selected string in the whole drawing.
You select "String1", "String2", "String3", the LISP will count every instance of "String1", "String2", and "String3" in the whole drawing.
Lee
  • 2 years later...
When I run this I am getting a chart that shows...
"SAVETIME" 15
"SAVETIME" 6
insted of the name of the string and the count of 16.
Am I doing something wrong????
Thanks so much!
Welcome to CADTutor Stephen.
I'm not sure which program you are referring to as there are many code posts in this thread, however, an updated version of this program can be found on my site here.
Let me know if you still have trouble using the program.
Lee
Referring to Counting instances of Mtext in Autocad 2012.
Any ideas???
Lee
Hi Lee,
His routine is very useful for me.
But it would be possible to mount the table in ascending order as: ST1, ST2, ST3... ST9, ST10, ST11...?
Thanks in advance.
