ok basiclly i need to create an adjusting screw (M10x1.5). i've created everything but this hex socket part whichs needs to be flat to flat 10 and a depth of 9. the thing is i dont understand where to input M10x1.5 and flat to flat and depth or where to select to get a hexagon type hole. this is what i have so far. in the picture the hex socket is wrong though cuz i used poly and extrude cut it but its supose to sorta look like this.
img403.imageshack.us/i/screws.jpg/
...thing is i dont understand where to input M10x1.5
Do you need a cut thread or will a cosmetic thread suffice?
Cut use Sweep tool.
Cosmetic use Thread tool.
Can't see your image for the hex cut, but that should be trivial. Zip and attach your ipt file here.
Have you gone through the tutorials in my signature?
ok i attached a zip of the picture and what i have done so far. i have no idea about the cut.
screwdia.zip
  • 2 months later...
you could use the content center and just place an M10x1,5 screw and modify it?
