I am running full AutoCAD2010 and am having an annoying problem with the multileaders.
When I draw a multileader vertically down the drawing from an item an click to end the leader function the 'tail' goes off to one side ie no longer vertical !!
Any idea's ??
If I draw it horizontally no problem - it stays horizontal but drawing a leader horizontally the rotating it 90 degrees so it become vertical not practical.
It's not snapping to anything incase you think that may be the case.
Set yourself up a new multileader style just for these types of uses (vertical with no landing). In the meantime, if it is just this one leader you can do this...
mleaderstyle > Modify > Leader Structure tab > Landing Settings. Uncheck the box for Automatically include landing. Then click OK and finally close. Now try it. Does it work the way you want?
ReMark - you were spot on.
I changed the landing setting to automatic include landing (previously off) but no distance - now works a treat - thanks.
You're entirely welcomed TomC. :)
