Hi
I need to get the path of the active project in AutoCAD using VBA. I have found autocad API (ace_getactiveproject) to find the path, but i dont know how to use it in VBA..
Is their any other way to get the path??
Thanks in advance
The Developer Help (ActiveX and VBA Reference) has a good example. In the help file search for SetProjectFilePath Example.
Thanks for ur input
i have one more query. I have created a new project in Autocad electrical. Is it possible to retive the Activeproject name using VBA?
thanks
Does this return the correct name?
currProjName = ThisDrawing.GetVariable("PROJECTNAME")
When is use this
currProjName = ThisDrawing.GetVariable("PROJECTNAME") statement it is returning empy string(currProjName ="" )
Instead of PROJECTNAME if I use "123"(My active project) am getting error "Error getting system variable"
help me out pls
thanks
It appears that the example I referred you to had errors. :?
Try the revised example below, and see if this is helpful.
Sub Example_SetProjectFilePath()
   ' This example finds the current project file information, changes
   ' that information, and finally resets the information back to the
   ' original values.
   Dim preferences As AcadPreferences
   Set preferences = ThisDrawing.Application.preferences
   ' Get the current project file information
   Dim currProjPath As String
   Dim currProjName As Variant
   If currProjName <> "" Then
       currProjPath = preferences.Files.GetProjectFilePath(currProjName)
   End If
   If currProjPath = "" Then
       MsgBox "There is no current project file or path. ", , "SetProjectFilePath Example"
   Else
       MsgBox "The current project file path is: " & currProjPath, , "SetProjectFilePath Example"
       ' Set new project file information.
       ' Change drive/path as necessary to match your system
       Dim newProjPath As String
       newProjPath = "C:/AutoCAD/"
       preferences.Files.SetProjectFilePath currProjName, newProjPath
       MsgBox "The new project file path is: " & newProjPath, , "GetProjectFilePath Example"
       ' Reset the project file information
       preferences.Files.SetProjectFilePath currProjName, currProjPath
       MsgBox "The project file path has been reset to: " & currProjPath, , "GetProjectFilePath Example"
   End If
End Sub
