Element visibility
I have a problem when drawing pipes and equipment. For example when i put a pump below a pipe, in a way that only half of the pump is visible. Part of the pump below the pipe is grayed out. Visible part looks somehow broken from the grayed out part. Is there some kind of adjustment, that alows this transitions to be cut clean, no empty gaps?
Options > MEP Display Control > B - Gap Width: Set this to 0".
