tzframpton Posted July 8, 2009 Share Posted July 8, 2009 Just wondering.... I thought there was a command that does this. Tons of fields in a drawing that I really don't wanna retype. Thanks in advance Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 8, 2009 Share Posted July 8, 2009 Explode, maybe. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 8, 2009 Author Share Posted July 8, 2009 tried it, no avail. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 8, 2009 Author Share Posted July 8, 2009 From the Help menu. Ah, I'm so lazy.... Sorry about that. Converting Fields to TextUse this procedure to convert a field to text. NoteThis procedure cannot be reversed. Navigate to the field you want to convert to text. Fields can be contained in AutoCAD text, multiline text (mtext), table cells, attributes, property set definitions, object properties, object styles., and project details. For information about inserting fields in text components, see Inserting Fields. Select the field, right-click, and click Convert Field to Text. Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted July 8, 2009 Share Posted July 8, 2009 I like these self answering threads. Quote Link to comment Share on other sites More sharing options...
NBC Posted July 8, 2009 Share Posted July 8, 2009 Explode should work - however it depends on how you use explode. XPLODE doesn't work, but EXPLODE seems to Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 8, 2009 Author Share Posted July 8, 2009 Explode should work - however it depends on how you use explode.XPLODE doesn't work, but EXPLODE seems to Tried both, doesn't work. Quote Link to comment Share on other sites More sharing options...
NBC Posted July 8, 2009 Share Posted July 8, 2009 you need some new dynamite Mr Quote Link to comment Share on other sites More sharing options...
anaskattayil Posted July 10, 2014 Share Posted July 10, 2014 I had a drawing with file name , date & time ( Field Rtext)in the right side corner of drawing sheet. Unfortunately its erased from me. please can you help me for making new one... or any lisp for that???? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 10, 2014 Share Posted July 10, 2014 I had a drawing with file name , date & time ( Field Rtext)in the right side corner of drawing sheet. Unfortunately its erased from me. please can you help me for making new one... or any lisp for that???? Have you tried using the OOPS command? If that doesn't work (seriously, try the OOPS command first), then refer to the screenshot where you can learn how to replace what you seem to have erased or misplaced. Quote Link to comment Share on other sites More sharing options...
anaskattayil Posted July 10, 2014 Share Posted July 10, 2014 Please check the attached drawing. i need like this. I think its from FIELD-RTEXT. Please help me.. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 10, 2014 Share Posted July 10, 2014 Try doing a PLOTPREVIEW, and you may find that it will be generated, when it is plotted, as I suspect that it is a PLOT STAMP, rather than a simple field which has been inserted. Quote Link to comment Share on other sites More sharing options...
mbrandt5 Posted August 12, 2015 Share Posted August 12, 2015 (edited) (defun C:R-FIELDS ( / del-field ss1 index item) (defun del-field (ent / edic) (if (setq edic (cdr (assoc 360 (entget ent)))) (dictremove edic "ACAD_FIELD") ) ) (if (= (getvar "TILEMODE") 0) (progn (setvar "TILEMODE" 1) (command "REGEN") ) ) (if (setq ss1 (ssget "X" (list (cons 0 "TEXT,MTEXT,MULTILEADER") (cons 67 0) ) ) ) (progn (setq index 0) (repeat (sslength ss1) (setq item (ssname ss1 index)) (if (del-field item) (entupd item)) (setq index (+ 1 index)) ) ) ) (if (setq ss1 (ssget "X" (list (cons 0 "INSERT") (cons 67 0) (cons 66 1) ) ) ) (progn (setq index 0) (repeat (sslength ss1) (setq item (ssname ss1 index)) (while (= (cdr (assoc 0 (entget (setq item (entnext item))))) "ATTRIB") (if (del-field item) (entupd item)) ) (setq index (+ 1 index)) ) ) ) (princ) ) This code will replace all fields within all text, mtext, and dimensions It will not convert fields where the MtextColumn Value is Dynamic...so for anyone that knows of a way to tweak it and make that happen it would be greatly appreciated Edited August 20, 2015 by mbrandt5 Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 12, 2015 Share Posted August 12, 2015 Dude - use some [ CODE ] Tags, please. Quote Link to comment Share on other sites More sharing options...
anniesmith Posted August 13, 2015 Share Posted August 13, 2015 Hi, I've tried to use your code, but in paper space, because it's where I have all my fields... I've disabled the space control inside your code to not switch to tilemode 1. I obtain no error, but all my fields stayed in place... Do you have an idea of the reason why it doesn't work in paper space ? To match my need, do you know about a code wich works in paperspaces (several layouts... But I don't mind in launching a comand in each one... For more detail you may visit http://sd-academy.com/ Quote Link to comment Share on other sites More sharing options...
mbrandt5 Posted August 20, 2015 Share Posted August 20, 2015 Annie...Here's a version of the code in paperspace... http://forums.augi.com/showthread.php?162398-Converting-All-Fields-To-text&p=1297299#post1297299 Quote Link to comment Share on other sites More sharing options...
rkent Posted August 20, 2015 Share Posted August 20, 2015 When I list a Field it shows as Mtext, I use Explode and it becomes Text. 2016. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 21, 2015 Share Posted August 21, 2015 When I list a Field it shows as Mtext, I use Explode and it becomes Text. 2016. That's normal behavior; if you dump the Visual LISP properties see TextString, or view an attributed block that's been populated via Fields in Properties pane, you'll see the resultant String output of the evaluated FieldCode. Explode merely gets the TextString and applies that to the resultant MText, etc. Cheers Quote Link to comment Share on other sites More sharing options...
rkent Posted August 21, 2015 Share Posted August 21, 2015 That's normal behavior; if you dump the Visual LISP properties see TextString, or view an attributed block that's been populated via Fields in Properties pane, you'll see the resultant String output of the evaluated FieldCode. Explode merely gets the TextString and applies that to the resultant MText, etc. Cheers The OP said it wasn't working for him, I simply posted that it worked as expected on my setup. Quote Link to comment Share on other sites More sharing options...
ayethzerothree Posted September 2, 2015 Share Posted September 2, 2015 to convert field into txt. I have two methods 1. if your fields are in text format only, just convert it into mtext using lee mac t2m lisp. then explode it 2. if your fields are in mtext format, just simply explode it. Quote Link to comment Share on other sites More sharing options...
