SmD71nG Posted July 8, 2009 Share Posted July 8, 2009 I need to edit a drawing to mimic a typical standard but the problem i am having right now is getting a line to match the needed linetype. I never created a linetype so I am not sure how to do so. I am using Autocad MEP 2010 without expresstools Attached is a picture of the desired linetype. (line with 3 box breaks) I have seen this linetype somewhere before, but can not remember which version it was or is it was an add on linetype. Quote Link to comment Share on other sites More sharing options...
chulse Posted July 10, 2009 Share Posted July 10, 2009 Is that a single line or a wide pline surrounded by 0 width continuous plines? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 14, 2009 Share Posted July 14, 2009 The linetype phantom is pretty close you could copy it and make a new one change the longer bar spacing increasing it. *PHANTOM2,Phantom (.5x) ___ _ _ ___ _ _ ___ _ _ ___ _ _ A, 15.875, -3.175, 3.175, -3.175, 3.175, -3.175 try changing the 15.875 to say 60 and make it a pline with a width. You may need a seperate edge line as previously suggested. Our stormwater drains are made up of 3 lines Quote Link to comment Share on other sites More sharing options...
