Hello,
I am looking for a routine to export the co-ordinates of line end points to a txt file.
I basically have lines radiating from the origin at 1 degree intervals for a full 360 degrees, each line is a different length. I need to find the co-ordinates of the lines end point.
I looked at the PO2txt lsp routine but I don't have points just lines. Is there an easy way to modify this lsp routine to look for lines rather than points?
Thanks for any help you may be able to give.
Lee
COOR - export of coordinates
Export of coordinates of the specified points, the chosen objects: points, blocks, polylines, splines in a text file or Excel.
Text file — txt, or csv.
Use PEDIT comand whith options Multiple to convert line to Polyline
**ADD** Sorry, your have AutoCAD LT 2000.
VVA has some great routines, but do you have access to the full version of ACAD to run them? :huh:
Hello,
In this case I am using dwg editor from solidworks. It does appear to run lsp routines.
Lee
