Apologies if this has been asked before, but is there any way I can create a circular viewport in AutoCAD 2008 LT.
Thanks:):)
In full AutoCAD you can use the MVIEW command to create nonrectangular viewports. Is there such a command in LT?
There is an MVIEW command, but the options are [ON/OFF/Fit/Shadeplot/Lock/Restore/LAyer/2/3/4].
:cry:
I came across this somewhere some time back, been using it ever since. Very useful.
Viewports.dwg
:cry:
That is odd. Try typing o at the command prompt anyway.
Here's an option. In paper space draw a circle. Then click on Modify > Object > Viewport and follow the prompts. Does that work?
i dont know if this is only in 2009 but in my layers toolbar i have a button to change object in paperspace to viewport?
I have that command in 2008 full. If you bring up the viewport toolbar and go in paperspace, you can draw a circle and use that command from the tool bar (Convert Object to Viewport). But again,I have the full versionso you would have to check.
:cry:
I have 2009 FULL and it says [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4]
So...I guess the OP doesn't have those options in LT.
there was a thread about this before. it was started by dipali.. some good and similar answers in there ;)
check below :)
In Acad 2008, there is another option. Like ReMark said, draw your circle in paper space. Then go to view > viewports > object, and select your circle.
I dont know if this works in 2002.
