hi friends,
i have doubts about querying the drawings through lisp.can anyone help me 2 proceed.
thanks in advance
regards
vivek
Guest Alan Cullen
Well vivekgrs,
That depends a lot on just what you are trying to query.
Would you care to eleborate a bit further?
thanks for ur immediate reply. i want 2 change the layer of blocks into blockname layer. i will explain u what i had done in autodesk map manually. first i attach the drawings, then click the current query and select define query. in that ,select location all and draw in query mode,after that select alter property then select layer. click expression & select blockname. then execute query. this things i want 2 write in lisp
(defun c:test (/)
 (and (ade_qryclear)
      (ade_qrydefine (list "" "" "" "location" (list "all") ""))
      (ade_qrysettype "draw")
      (ade_qrysetaltprop t)
      (ade_altpdefine "layer" ".blockname")
      (ade_qryexecute)
ade_ - is it SQL extension libruary for AutoCAD Map? It's seems for AutoCAD Map only...
that's true
ADE stands for AutoCAD Data Extension
hi vovka,
thanks for ur great effort. its really helped me alot.
regards
vivek
  • 8 years later...
hello, someone could help me?
why this doesnt work?
(setq VAL (getstring "\nNumero de Cable:"))
(ade_qryclear)
(ade_qrydefine '("" "" "" "Data"  ("objdata" "Cable.NUM" "=" "VAL")""))
(ade_qryexecute)
Edited by SLW210
added code tags
