Although I don't really use it I've seen mention of a command EXTRIM, perhaps that will help on your way to a complete solution?
This boundary you speak of. Is it a series of straight lines or is it more freeform (curvy)? I ask because there is another workaround. It's not elegant but it does work under certain conditions. You can use the ERASE command with the WP option.
When you are prompted to erase objects type WP and then press ENTER instead. AutoCAD will prompt you with First polygon point. At this juncture select the first point (most likely it will be an endpoint/intersection) and work your way around the boundary to the point at which you started. Each time you make a pick AutoCAD will prompt you to Specify endpoint of line or [undo]. After the last pick press ENTER. AutoCAD will now inform you how many objects it found. It will then prompt you once again to Select objects. Pressing ENTER after this prompt will erase everything inside the boundary. Entities that cross the boundary can be trimmed away using the TRIM command. If there are a number of these then use the Express Tools EXTRIM command to speed things up. It ain't fast but it does work.
ReMark is truly an Luminous Being, but I do have a little additional info to his post....
WP is window polygon and when you select that option everything that is completely inside the window is selected. There is also CP which is crossing polygon and that selects anything that touches the polygon.
Good Luck and let us know how it turns out.
Dang...forgot the CP option. Thank you for catching my error of omission Ryder. I shall go flog myself (10 lashes?) right now. Ow! Ow! Ow! LOL
ReMark you're killing me.....ROFLMAO
Hello ReMark,
The LSP routine you provided just work opposite to what i wanted. Haha. I think i will request a LSP routine in the LSP section.
Hello Ryder,
Thank you for your reply!
Appreciate all your efforts.
:):lol:
Carl.
Hello Everyone,
I have a question on deleting part of my drawing using "drawn boundary" (From another layer). If any part of my drawing touches/stay on the outline of my defined "boundary", they are to be deleted. (My boundary can be any shapes)
I would like to see if a LSP routine can get my task in a faster way.:wink:
I have attached a dwg file, showing an example on how it is done.
Currently, i am doing this task manually. It becomes a pain when the drawing is huge.
PS: I have posted this question in the "AutoCAD General" and found that a LSP routine can help me better. :)
Your help is greatly appreciated.:D
Thanks!
Carl
Example.zip
Yes it can be done, but from how i would do it, the code would be quite tediouse to wright.
(defun C:brv(/ sset2 sset plist cntr )
 (setq cntr 0)
 (setq sset (ssget "X" (list(cons 8 "Boundary"))))
 (while(< (setq cntr(+ cntr 1)) (sslength sset))
   (setq ent (entget (ssname sset cntr)))
   (setq plist nil)
   (foreach c ent
     (if(= 10 (car c))
   (setq plist (append plist (list (cdr c))))
   (setq plist(append plist( list (car plist))))
   (setq sset2 (ssget "F"   plist '((-4 . "<AND")(-4 . "<NOT")(8 . "Boundary")(-4 . "NOT>")(-4 . "AND>"))))
   (command"erase" sset2"")
   (setq sset2 (ssget "WP" plist))
Thank you for reply.
I do understand it is not easy.
But i still hoping i can have a LSP that can assist me on this.
It will greatly save my time.
hey ollie
You code barly didnt work
I fixed it below.
only selection set & count not done (1st 2 lines) :D
GW!
CarlTonDor
Would the boundary's on the the boundary layer?
Or do you want to select them?
Any one
How do you delete an enity with out the command "delete"
Weird thing is, i can delete a file or a regstry file, but not a enity
(defun C:brv (/ sset ent plist sset2 )
 (setq sset (ssget "X" '((8 . "Boundary")))
  cntr 0)
   (setq plist nil)
   (foreach c ent
     (if(= 10 (car c))
hey ollie
I fixed it below.
GW!
CarlTonDor
  cntr 0)
   (setq plist nil)
   (foreach c ent
     (if(= 10 (car c))
Yeah sorry about that I hadn't localised my variables until testing was finished, hence the counter problem.
I chose to use the list cons method for creating the selection set incase the OP wanted to replace the "Boundary" with a variable or wild card selection
Any one
(entdel ent)
Entdel will delete an entity
EDIT:
In retrospect I didn't need the
Ollie
Yes, you're right but I did mention in my post, along with the link, that it would have to be modified. It was supposed to be a starting point and not a fix. What about using Erase with the CP option; did you try it?
Sorry for the mentioning. I do tried using the "WP" and "CP" function. It works and i had my lesson learnt. Thanks!
However, most of the time, the "boundary" is already drawn (By other team) and i have to manually to delete my drawings that collapsed with the boundaries.
Yes. It will be faster but i still will be doing this time 100 over times.
Some may reach 500. :shock:
Oh My, It works! Thank you ALL!
I am wondering if i can edit my request.
Can i have the deleted items shifted to another layer? (layer name "DELELE")
In this case, i can check and know what is deleted.
I am getting so excited now :D :)
Carl
Some times i think i am a complete idot,
Here is the code using ollies methods
You can change the name "deleted" to what ever you want.
All the items will be on a blue, no plot layer
(defun layerchanger (ss / ed TheLayer)
(setq TheLayer "deleted")
(if ss
  (if (not (tblsearch "layer" TheLayer))
   (entmake
    (list
      (cons 0 "LAYER")
      (cons 100 "AcDbSymbolTableRecord")
      (cons 100 "AcDbLayerTableRecord")
      (cons 2  TheLayer)
      (cons 70 0)
      (cons 62 2)
      (cons 6 "CONTINUOUS")
      (cons 290 0)
      (cons 370 0)
  (setq ed (entget (ssname ss 0))
   ed (subst (cons 8  TheLayer) (assoc 8 ed) ed)
  (entmod ed)
(setvar "cmdecho" 0)
  cntr -1)
   (setq plist nil)
   (foreach c ent
     (if(= 10 (car c))
   (layerchanger sset2)
 (setvar "cmdecho" 1)
Sorry, it keeps missing one item
