I believe I found this LISP on this site a while back, and it actually works great. Its for duplicating and inserting a block, which also asks for for new attribute definitions.
What i need help with, is every time the block is duplicated it asks for scale and rotation once inserted. I would like to get rid of those 2 steps if possible.
Any help always appreciated! :)
;;; Create a duplicate block definition
(defun c:DD (/ en ed bname nname fname fdia)
 (if (and (setq en (entsel "\nPick block: "))
          (setq ed (entget (car en)))
          (= (cdr (assoc 0 ed)) "INSERT")
          (setq nname (getstring nil "\nNew name: "))
     ) ;_ end of and
     (setq bname (cdr (assoc 2 ed))
           fname (strcat (getvar "TEMPPREFIX") nname ".DWG")
     ) ;_ end of setq
     (if (findfile fname)
       (vl-file-delete fname)
     ) ;_ end of if
     (setq fdia (getvar "FILEDIA"))
     (setvar "FILEDIA" 0)
     (command ".-WBLOCK" fname bname)
     (command ".-INSERT" fname)
     (setvar "FILEDIA" fdia)
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
Ugly. but will work....
     ) ;_ end of and
     ) ;_ end of setq
     ) ;_ end of if
     (command ".-INSERT" fname (getpoint) 1 1 0)
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
so all you want is a block thats the same as another block just with a different name?
I have a block with 3 attributes, which i need to repeatedly copy/paste for different info on different parts of the drawing.
The only input i actually need when inserting the block, is for the block name and for another attribute, which i setup when i make the block.
This lisp does just that, except it asks for scale/rot when i go to insert the block, and its just a couple of unneccesary steps for me
