Jhun Gonzalo Posted July 12, 2009 Share Posted July 12, 2009 Hi to all, Good day, I have some question about "convertpstyles", because i have +100 sheets drawings that created on release 14, the print style are not applicalbe to higher version so i will convert the plot style by "convertpstyle" all the drawings 1 by 1, is there any easiest way like BATCH CONVERTPSTYLES that will select all drawings files to convert the plot stye all the drawings. Please help me on this:oops: Many thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 12, 2009 Share Posted July 12, 2009 One way might be to use a script file. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 13, 2009 Share Posted July 13, 2009 Jhun: What are you converting from and to? Are you converting from CTB to STB? Quote Link to comment Share on other sites More sharing options...
Jhun Gonzalo Posted July 13, 2009 Author Share Posted July 13, 2009 Yes Remark, STB to CTB, script are ok Mark, i already set it on script if you have another options i'll try it also Many Thanks:) Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 13, 2009 Share Posted July 13, 2009 No other suggestion at this time. I was just following up with you. I had to take some time off over the past couple of days so I wasn't sure where things had left off. That's all. Quote Link to comment Share on other sites More sharing options...
