ARGV Posted July 12, 2009 Posted July 12, 2009 Can inventor import solidWorks Assembly files and figure out the mates and such, or do they all need to be re-done? Can it import .SLDPRT and maybe .SLDDRW files without too much trouble? thanks again, -Argv Quote
JD Mather Posted July 12, 2009 Posted July 12, 2009 Inventor will import *.sldprt files as base solids. The sketch and feature tree can be rebuilt with Feature Recognition (works similar to SolidWorks). Inventor will import *.sldasm files. The assembly constraints must be rebuilt. Inventor will not import SolidWorks drawing files. Quote
ARGV Posted July 14, 2009 Author Posted July 14, 2009 Inventor will import *.sldprt files as base solids. The sketch and feature tree can be rebuilt with Feature Recognition (works similar to SolidWorks). Inventor will import *.sldasm files. The assembly constraints must be rebuilt. Inventor will not import SolidWorks drawing files. So it sounds like re-making all the drawings is probably the worst part for us, as we have many parts with many drawings. Are there any tools, like a massive import tool that would help convert a large batch of parts and assemblies to inventor? How is the integrity and/or compatibility of solidworks -> inventor imports? Any chance of error, or is the import process pretty seamless? Any other pertinent information for a company that might be looking to switch to all Autodesk, if only to save from having to buy two licenses per year? thanks. -Argv Quote
JD Mather Posted July 14, 2009 Posted July 14, 2009 If you get the software you might start with this document to avoid a lot of frustration http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf I don't have an update for 2010 Ribbon interface, but if you've gone through the same thing with SolidWorks ribbon you should be fine. Inventor includes license of AutoCAD for free. Unless a part/assembly changes you should be able to simply use the legacy drawings going forward. Quote
ARGV Posted July 14, 2009 Author Posted July 14, 2009 If you get the software you might start with this document to avoid a lot of frustration http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf I don't have an update for 2010 Ribbon interface, but if you've gone through the same thing with SolidWorks ribbon you should be fine. Inventor includes license of AutoCAD for free. Unless a part/assembly changes you should be able to simply use the legacy drawings going forward. Ok, sounds good. I should be getting the trial soon hopefully. We'll see how it goes. thanks again, -Argv Quote
