electrongod Posted July 13, 2009 Posted July 13, 2009 Autocad Newbie here. I purchased some electrical blocks and I can't import them to Design Center. Is this not possible? Great site. Thanks for any help. Quote
fuccaro Posted July 13, 2009 Posted July 13, 2009 Hello Electrongod and welcome in the forum! Create a new drawing and insert all those blocks. Save the drawing in a handy place and close it. In the drawing you wish to insert a block in, open the design center and navigate to the drawing previously saved. You should see the blocks. Quote
CADMASTER1128 Posted July 13, 2009 Posted July 13, 2009 You can also create a folder to keep all your blocks in and then in DC select the file path that you created that way you will always have your blocks. Quote
electrongod Posted July 13, 2009 Author Posted July 13, 2009 Thanks fuccaro, You have helped me understand this thing a lot better. You'll be hearing from this cad virgin again, Quote
electrongod Posted July 13, 2009 Author Posted July 13, 2009 Thanks cadmaster. Maybe someday I will be one... Quote
fuccaro Posted July 13, 2009 Posted July 13, 2009 I wrote you the simplest way to get started. As Cadmaster suggested, you could keep some order in your blocks. Save different blocks in different drawings and open only the desired one. Quote
