i need help for drawing L-section levelling n cross section levelling from autocad 2007
pls help me
Guest Alan Cullen
Quickest way to do it is to ID your points as Chainage and Level. Then draw a polyline using absolute coordinate entry.... X,Y
Enter your Chainage as the X value, and your level as the Y value.
That will give you a profile at 1 to 1 distortion (which is fine for cross sections).
Apart from that, you need to get a specific version of AutoCad, and learn how to use it. It's all a bit much for us to teach you here, but we do have a lot of tutorials here.
can i get tutorial for x-section n longitudinal section levelling
Are you using Civil 3d if so then there are tutorials which explain how to do it.
If not you need to elaborate a bit more what you are trying to do.
  • 3 years later...
can i get tutorials for doing cross section in civil 3d pls send me
