woodman78 Posted July 14, 2009 Posted July 14, 2009 Hi, I want to set up some variables to combine a text with a variable portion to produce a new variable. Ex: (setq a 1500) (setq b "CCC_DR" + a) (setq c "CCC_Services" + a) I will then use b and c to create a layer and alinetype with the combined names. Thanks Quote
Lee Mac Posted July 14, 2009 Posted July 14, 2009 Variables can only be of one type, i.e, STRing, INTeger, REAL, LIST etc. You can test this type, using the "type" function (obviously...).. So, if your variable "a" is an INTeger, you will need to convert it to a STRing before combining it with "CCC_DR" And you can then use "strcat" to concatenate the strings: (setq b (strcat "CCC_DR" (itoa a))) Hope this helps! Lee Quote
Lee Mac Posted July 14, 2009 Posted July 14, 2009 No problem, if you get stuck at all, just shout Quote
woodman78 Posted July 14, 2009 Author Posted July 14, 2009 Lee, I did get a bit stuck. I am trying to integrate it into my code. When I run this I am getting an error: "bad argument type: fixnump: nil". I have set d to be 1500 at the start as a default value so I'm not sure why I'm getting this. I think the COND is setup right since I set the value of d there based on the size. (defun C:ESS02 () ;define function (setq dcl_id (load_dialog "ESS.dcl")) ;load dialog (setq d 1500) ;(setq b "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500") (if (not (new_dialog "ESS" dcl_id) ;test for dialog );not (progn (alert "Can not find your dcl file") (exit) ;exit if no dialog ) );if (set_tile "1500" "1") ;Set radio_button T1 as default (setq hole "S1") ;Set variable hole to S1 as default (action_tile "1500" "(setq hole \"S1\")") ;*store hole type (action_tile "1350" "(setq hole \"S2\")") ;*store hole type (action_tile "1200" "(setq hole \"S3\")") ;*store hole type (action_tile "1050" "(setq hole \"S4\")") ;*store hole type (action_tile "900" "(setq hole \"S5\")") ;*store hole type (action_tile "750" "(setq hole \"S6\")") ;*store hole type (action_tile "675" "(setq hole \"S7\")") ;*store hole type (action_tile "600" "(setq hole \"S8\")") ;*store hole type (action_tile "525" "(setq hole \"S9\")") ;*store hole type (action_tile "450" "(setq hole \"S10\")") ;*store hole type (action_tile "375" "(setq hole \"S11\")") ;*store hole type (action_tile "300" "(setq hole \"S12\")") ;*store hole type (action_tile "225" "(setq hole \"S13\")") ;*store hole type (action_tile "150" "(setq hole \"S14\")") ;*store hole type (action_tile "cancel" ;if cancel button pressed "(done_dialog)(setq userclick nil)" ;close dialog, set flag );action_tile (action_tile "accept" ;if O.K. pressed "(done_dialog)(setq userclick T))" );action tile (start_dialog) ;start dialog (unload_dialog dcl_id) ;unload (if userclick ;When OK button is selected (cond ;And one of the following conditions apply ((= hole "S1")(setq d 1500)) ;If S1 selected, d = 1500 ((= hole "S2")(setq d 1350)) ;If S2 selected, d = 1350 ((= hole "S3")(setq d 1200)) ;If S3 selected, d = 1200 ((= hole "S4")(setq d 1050)) ;If S4 selected, d = 1050 ((= hole "S5")(setq d 900)) ;If S4 selected, d = 900 ((= hole "S6")(setq d 750)) ;If S4 selected, d = 750 ((= hole "S7")(setq d 675)) ;If S4 selected, d = 675 ((= hole "S8")(setq d 600)) ;If S4 selected, d = 600 ((= hole "S9")(setq d 525)) ;If S4 selected, d = 525 ((= hole "S10")(setq d 450)) ;If S4 selected, d = 450 ((= hole "S11")(setq d 375)) ;If S4 selected, d = 375 ((= hole "S12")(setq d 300)) ;If S4 selected, d = 300 ((= hole "S13")(setq d 225)) ;If S4 selected, d = 225 ((= hole "S14")(setq d 150)) ;If S4 selected, d = 150 ;(t (princ "\nNothing changed.")) ;_ end of optional else condition ) ;End cond ) ;End if (princ) ;Exit quietly ) ;End defun (princ "\nThis loaded fine") (setq a (strcat "CCC_DR_" (itoa d))) (setq b )strcat "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_" (itoa d))) (if (= (tblsearch "ltype" a) nil) (command "-linetype" "l" a "acadiso.lin" "") (princ)) (graphscr) (command "._-layer" "N" b "M" b "L" a b "C" "84" b "LW" "0.3" b "" ) (command "pline" pause "width" "0.0" "0.0" pause "width" "0.0" "0.0") (princ) ) Quote
Lee Mac Posted July 14, 2009 Posted July 14, 2009 There is quite a lot wrong with your code - you have parts of the code outside of the function definition, and your parentheses aren't right. I have re-written your code and made a few comments, this isn't tested, but take note of the way I have altered it. (defun C:ESS02 (/ dcl_id d hole userclick a b) ;; Make sure that you localise your variables! (cond ((minusp (setq dcl_id (load_dialog "ESS.dcl"))) (princ "\n<< DCL File not Found >>")) ((not (new_dialog "ESS" dcl_id)) (princ "\n<< Dialog could not be Loaded >>")) (t (setq d 1500 hole "S1") (set_tile "1500" "1") ;Set radio_button T1 as default (action_tile "1500" "(setq hole \"S1\")") (action_tile "1350" "(setq hole \"S2\")") (action_tile "1200" "(setq hole \"S3\")") (action_tile "1050" "(setq hole \"S4\")") (action_tile "900" "(setq hole \"S5\")") (action_tile "750" "(setq hole \"S6\")") (action_tile "675" "(setq hole \"S7\")") (action_tile "600" "(setq hole \"S8\")") (action_tile "525" "(setq hole \"S9\")") (action_tile "450" "(setq hole \"S10\")") (action_tile "375" "(setq hole \"S11\")") (action_tile "300" "(setq hole \"S12\")") (action_tile "225" "(setq hole \"S13\")") (action_tile "150" "(setq hole \"S14\")") (action_tile "cancel" "(done_dialog)") ; Userclick will be nil anyway (action_tile "accept" "(done_dialog)(setq userclick T))") (start_dialog) ;start dialog (unload_dialog dcl_id) ;unload (if userclick ;When OK button is selected (progn (setq d (cond ;And one of the following conditions apply ((= hole "S1") 1500) ((= hole "S2") 1350) ((= hole "S3") 1200) ((= hole "S4") 1050) ((= hole "S5") 900) ((= hole "S6") 750) ((= hole "S7") 675) ((= hole "S8") 600) ((= hole "S9") 525) ((= hole "S10") 450) ((= hole "S11") 375) ((= hole "S12") 300) ((= hole "S13") 225) ((= hole "S14") 150))) (setq a (strcat "CCC_DR_" (itoa d)) b (strcat "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_" (itoa d))) (if (not (tblsearch "LTYPE" a)) (command "_.-linetype" "_l" a "acadiso.lin" "")) (command "._-layer" "_N" b "_M" b "_L" a b "_C" "84" b "_LW" "0.3" b "" ) (command "pline" pause "width" "0.0" "0.0" pause "width" "0.0" "0.0"))))) (princ)) Quote
