dualxhst Posted July 14, 2009 Posted July 14, 2009 When XREFs appear on parent drawing all the coloring of the XREF is darkened, as if it were locked. Friend at different company cant even create this problem with his. ANy ideas??? Quote
rkmcswain Posted July 14, 2009 Posted July 14, 2009 I believe it is: XFADECTL Nope, it's XDWGFADECTL. XFADECTL controls fading during REFEDIT. Quote
chulse Posted July 14, 2009 Posted July 14, 2009 From Help: XDWGFADECTL Type:Integer Saved in:Registry Initial value:70 Controls the dimming for all DWG xref objects. The valid XDWGFADECTL system variable value is between -90 and 90. When XDWGFADECTL is set to a negative value, the Xref Fading feature is not turned on, but the setting is stored. 0 DWG xref objects are not faded. >0 When the value is positive, controls the percent of fading up to 90 percent. Quote
rkmcswain Posted July 14, 2009 Posted July 14, 2009 I assume it's new in 2010... Yep. Complete reference: http://www.hyperpics.com/system_variables/index.asp Quote
ronjonp Posted July 14, 2009 Posted July 14, 2009 I assume it's new in 2010... No wonder it did not work for me Quote
dualxhst Posted July 15, 2009 Author Posted July 15, 2009 Bingo! Thanks guys, that was driving me crazy! Quote
