Is there any way to globally change text height across a drawing that has many blocks with attributed test. I can do them individually with no problems, but when the drawing has 200 blocks it is time consuming. I am using AutoCAD 2008
You can't do it using BATTMAN and ATTSYNC ?
This is assuming these 200 blocks are all from one block definition. if its 200 different blocks you may have to look into scripts to get it done.
All of the blocks I am trying to edit are not from the same block definition. The drawings were provided to me as is...not the way I would of done it.
Then nocturne is right you will need a lisp.
