HI EVERYONE
I JUST CONVERTED A multiple pages dwf FILE INTO CAD FORMAT using ACME cad convertor
but when i i open the file in cad i only see those pages as different layouts in autocad
and when i switch to model space i dont see anything
how can i see the drawings in model space.
i want to edit them
thanks
Are the drawings objects on the Layout space itself?
try to check if there are any veiwports
no idea
i just converted a dwf file with several pages
into cad format
and each page became layout in autocad
and i checked
there are no viewports
the model space is just blank even after i do zoom extents
thanks
So it sounds like everything is on the Layout then. Can you click on objects there and such? You can edit stuff in Layout-space just the same way that you do in Model Space. If you want to move it from the layouts to the model - try using the CHSPACE command I believe it's called (haven't got ACAD here to check) to copy between spaces.
