MRAKA Posted July 15, 2009 Posted July 15, 2009 Does anyone know how to make text transparent? I want to write a piece of text across a drawing (like a watermark) but still see behind it? Any ideas? Andrew Wales Quote
ReMark Posted July 15, 2009 Posted July 15, 2009 We used an outlined font and place it on it's own layer. The layer is assigned a light lineweight. The text size is fairly large, compared to that normally used, so it does stand out. Quote
bobsy852 Posted April 12, 2011 Posted April 12, 2011 ReMark, any chance you can give me an example of an outlined font as I'm trying to do the same thing and struggling! Quote
ReMark Posted April 12, 2011 Posted April 12, 2011 ReMark, any chance you can give me an example of an outlined font as I'm trying to do the same thing and struggling! Will this do? If you like it PM me with your email address. Quote
Dana W Posted April 12, 2011 Posted April 12, 2011 I made a sorta transparent watermark of my initials by hatching some exploded text and then erasing all but the hatch, then making it a block. I hatched with arsand so I would at least have a degree of control over the density by using the hatch scale factor. Quote
Ryder76 Posted April 12, 2011 Posted April 12, 2011 I haven't ever done this, but what if you make a ctb utilizing screening and dithering for a particular color and then make a layer with that color and put your text on it. Might work. Quote
designerstuart Posted April 12, 2011 Posted April 12, 2011 PM me with your email address just out of interest why PM? if you are not allowed to post it for copyright issues, how come you can email a copy to someone? i notice the same has been said elsewhere, about exactly the same font. Quote
BIGAL Posted April 13, 2011 Posted April 13, 2011 this may work You can explode text to be outlines need 26 of them then hatch each one and set the transparency of the solid hatch ? Check the recent posts for CNC link to exploding text Quote
Dana W Posted April 13, 2011 Posted April 13, 2011 2008 doesn't have transparent hatch. bummer. Quote
TheTriscut Posted January 15, 2014 Posted January 15, 2014 Hello Andrew and others. This worked for me in AutoCAD 2006. I our office we only print black and greyscale. There is no Solid color that is transparent and exploding text and using hatches is a pain. You can assign a color in your plot style to have a low screening level ( I used 15) so that it prints much lighter. Write your text in Model Space separate from your drawing and give it it's own Model Viewport in Paperspace. right click on the viewport for the lighter text and say send to back so that the text will print behind everything else and you can see everything in front of it. This way you can print your water mark behind multiple viewports and have it consistent on all of your sheets. Nich Quote
