MADHATTA Posted July 15, 2009 Posted July 15, 2009 I am using ACADE 2010 and am after a trunking command available for use in the panel layout. Is there one available to anyone's knowledge? Quote
The Buzzard Posted July 15, 2009 Posted July 15, 2009 I am using ACADE 2010 and am after a trunking command available for use in the panel layout. Is there one available to anyone's knowledge? When you say trunking command, Are you refering to trunk cabling with terminations and all that kind of stuff? Quote
MADHATTA Posted July 15, 2009 Author Posted July 15, 2009 I'm refering to when we layout components into a panel as a layout for the workshop to manufacture to. As far as I can see there is no command to add plastic cable trunkings around the panel easily. The software I used before had a a trunking command that let me choose what size of trunking I wanted then I could insert onto a backplate at a specified point to a specified length Quote
The Buzzard Posted July 15, 2009 Posted July 15, 2009 I'm refering to when we layout components into a panel as a layout for the workshop to manufacture to. As far as I can see there is no command to add plastic cable trunkings around the panel easily. The software I used before had a a trunking command that let me choose what size of trunking I wanted then I could insert onto a backplate at a specified point to a specified length Is this the plastic wrapping that holds the cabling together for a route or is it similar to panduit cable wireway? Can you provide a drawing? Quote
MADHATTA Posted July 15, 2009 Author Posted July 15, 2009 like the panduit stuff. Rigid c shape plactic channel with lid that clips on once wires are run Quote
The Buzzard Posted July 15, 2009 Posted July 15, 2009 like the panduit stuff. Rigid c shape plactic channel with lid that clips on once wires are run That is not really hard to do. You most likely would need to specify a width and length and maybe place it on a specific layer and of course an insertion point. Do you want this to be a line, polyline or block? Please provide an example so I do not have to ask alot questions? Then we can knock all the small quirks from it as we go. Quote
The Buzzard Posted July 15, 2009 Posted July 15, 2009 That is not really hard to do. You most likely would need to specify a width and length and maybe place it on a specific layer and of course an insertion point. Do you want this to be a line, polyline or block? Please provide an example so I do not have to ask alot questions? Then we can knock all the small quirks from it as we go. Sorry I just saw your image now. I know what you are refering to. I prefer a drawing so I can see exactly how you want this done. Quote
MADHATTA Posted July 15, 2009 Author Posted July 15, 2009 this is what I am used to with program currently using (aceri's Electrical Designer) which is an overlay program over AutoCad Quote
The Buzzard Posted July 15, 2009 Posted July 15, 2009 this is what I am used to with program currently using (aceri's Electrical Designer) which is an overlay program over AutoCad I thought this was a LISP request for a program to make wireway. Your thread has been move to Electrical for some reason. Quote
MADHATTA Posted July 15, 2009 Author Posted July 15, 2009 that was originally. Forum moderator must have moved it Quote
The Buzzard Posted July 15, 2009 Posted July 15, 2009 that was originally. Forum moderator must have moved it MADHATTA, Do you still want a lisp routine? If so, I need a drawing file of the object. Not an image file. I need to know the entity type, color, layer, text style, and drawing settings. I prefer that you supply a drawing so that I can get this information without asking many questions as it will only slow things down and lead to possible errors without it. Also what command syntax do you want to use to start the program? It must not conflict with another program you are using. I can get started as soon as you can supply this drawing file. Also if you have manufacturer specifications for the wireway, This will also be needed as well. Let me know. The Buzzard Quote
