URGENT - 3D in layout with multiple section plane?
Hello,
I just designed a pump room with tons of items, now i need to print this room into multiple plan (section a, b, c, etc) there is so many stuff that i need to hide depending on the section i am focusing on.
The sectionplane command work wonderfully, except i cannot use 2 different section in my layout, everytime i use one every viewport are updated to only 1 section at time, and i want to use multiple section,
i created 2 view that i linked to sectionplane like
View-A --> linked to --> Section-A
View-B --> linked to --> Section-B
Now i'm out of idea and i need to print this ASAP!
thank you
I'm no expert with creating sections from 3D in AutoCAD but if I remember rightly you could use 'section' to get your sections but you'll have to live with the fact that they won't update with the model.
I use Solidworks for this and it really is a fantastic tool.
i just discovered 3DCLIP this is AMAZING i can make dozen of independent section in multiple VP wow.
Thanks anyways :)
