Dipali Posted April 25, 2008 Posted April 25, 2008 my normal dimension style has text above dmension line & I want to add 'typical' to it below dimension line. I have done this lot of time in my previous job an year back. but I can't seem to remember what to type between dimension text & the word I want to add in edit text box, so that it appers below dimension line. Quote
lpseifert Posted April 25, 2008 Posted April 25, 2008 Here's one way... Properties > Text override \X typical Quote
Dipali Posted April 25, 2008 Author Posted April 25, 2008 Here's one way...Properties > Text override \X typical THANKS FOR THE HELP iF U DON'T USE U TEND TO FORGET THIS SORT OF THINGS. YOU SHOULD ADD THIS TO 'TIP OF THE DAY' SECTION Quote
ReMark Posted April 25, 2008 Posted April 25, 2008 If you are placing text below a dimension line such as TYP. you can attach the text to the dimension by placing a \X right after the default value "" and typing in your text. Dang it Lpseifert...you beat me to the punch! Curses...foiled again. Quote
lpseifert Posted April 25, 2008 Posted April 25, 2008 ...you beat me to the punch! Curses...foiled again. ya gotta get up pretty early... Quote
ReMark Posted April 25, 2008 Posted April 25, 2008 I did. 5:00 a.m. But the early bird in this case was you! Quote
neophoible Posted September 5, 2013 Posted September 5, 2013 I'm sure you're welcome. These days, you should be able to double-click on the dimension text to invoke TEdit (TEXTEDIT). Then you can go to the end of the dimension text--I use the End key--hit Return and begin typing on the next line. Quote
