stomperxj Posted July 18, 2009 Posted July 18, 2009 Hello all- New guy with his first post. I recently got some work to modify some files for a guy. A lot of the parts are tubes for an engine cage of some sort. I am having problems figuring out how they were drawn and how to modify them. Here's a couple screens of one part: I am supposed to shorten it by .3". In the model it looks like he extruded it into a work plant instead of chopping the end off with a subtraction/cut. Also, I am having trouble figuring out how the work planes are rotated on the circular cut at the other end. There is "reference" geometry on an angled work plane. I used Inventor a few years ago but all that has been pushed out of my brain with useless song lyrics and other garbage... I am using Inventor 2010... Thanks for any help Jess Quote
JD Mather Posted July 18, 2009 Posted July 18, 2009 I used Inventor a few years ago but all that has been pushed out of my brain with useless song lyrics and other garbage... So you equate knowledge of the use if Inventor with useless garbage? Good luck. Quote
stomperxj Posted July 18, 2009 Author Posted July 18, 2009 So you equate knowledge of the use if Inventor with useless garbage? Good luck. That was meant as a joke, sorry... I just have forgotten a lot that i have learned about it because I haven't used it in a few years... Quote
