tzframpton Posted July 20, 2009 Posted July 20, 2009 I think this is a question for the Civil / Survey guys. I am trying to locate the origin point of a BIM file and it has Northing and Easting with Elevation notes on it. Can I post these and get some help? Thanks.... Quote
tzframpton Posted July 20, 2009 Author Posted July 20, 2009 Here are the files.... hopefully this makes sense, lol. Thanks for the help man. Coord Table.pdf 09067_FINAL MODEL-COORD.pdf Quote
NBC Posted July 20, 2009 Posted July 20, 2009 Whew, I've no idea, based upon the info in those pdf files Quote
Car5858 Posted July 20, 2009 Posted July 20, 2009 I had a look and plotted the Coord's. Ithink this is what you were looking for; #137 Command line entry= Point> 4993.679956,4996.331511, 99.98> enter. This is the X,Y,Z of that position. Note that This is done in 2009 2D but the info is there to convert to 3D. Quote
eldon Posted July 21, 2009 Posted July 21, 2009 Usually, Northings are Y, Eastings are X and Elevations are Z, so this is the way I would have plotted a line joining the points (I have just labelled pt 140 with its coordinates). I seem to be at a difference from Car5858 Quote
Car5858 Posted July 21, 2009 Posted July 21, 2009 I was not sure I mine was correct Eldon, Now that I have thought about it some more I see my error. Thanks for the correction. Quote
rustysilo Posted July 21, 2009 Posted July 21, 2009 If you have the coord table in a text or spreadsheet format you could utilize the importxyz lisp that jeffery p. sanders did to import them all at once. You may have to rearrange the columns and get rid of the extra columns. Quote
dent Posted August 24, 2009 Posted August 24, 2009 To manually enter coordinates you enter the Easting first, then the northing (That's X,Y). The coordinates that you have appear to be in feet and on a local project grid system base on an assumed coordinate value on am initial control point with assumed coordinates of N5000.00, E5000.00 and an assuned elevation on that point of 100.00 This is pretty much a "standard" in surveying. Some use 10000,10000,100.00 for an origin depending on the size of the job. Note that none of this data is on any state plane coordinate system or any real vertical datum. ALL is assumed, but all of it will be correct relative to itself. Quote
Hippe013 Posted February 14, 2011 Posted February 14, 2011 @ North9ON Yes. Provided that you know the Coordinate System that the work was done in and obviously you do since you were using GPS. Quote
sinc Posted February 15, 2011 Posted February 15, 2011 What does "locate the origin point" mean? Do you mean you're trying to locate where it's at in relation to the Earth? Those look like assumed coordinates, so you would also need the coordinates of some control points on your job site. Then you should be able to perform any field stakeout or data collection using those points. If you want to combine this with GIS information, you'd need to equate your assumed coordinate system to a defined coordinate system like your local State Plane or UTM grid. For that, you'd need both the assumed coordinates for some control points, as well as the State Plane coordinates of the same control points. Quote
