I have inserted a block which has a wide polyline. in modelspace looks ok, but in paperspace it shows only the outline of the polyline.
i tried Textfill, it doesn't solve it. the block and the dwg has the same ltscale.
is there a setting in paperspace for that?
Goto your paperspace Layout Tab, doubleclick within the viewport; set SHADEMODE to something other than 3D Hidden.
Thanks, but fillmode is 1, i changed it to 0 and back to 1 again. it doesn't make any difference, it changes only in modelspace.
shademode was "as displayed".
any other thoughts?
try changing shademode to something like 2D Wireframe.
it didn't work until i deleted the old viewport and created a new one. probably was a setting of the viewport. still don't know what setting, though :)
  • 1 year later...
I was told by one of our cad techs to set UCS to world and then type "plan" at the command line. The reason being is your UCS is off plan view and you are seeing it at an angle. Doing this should reset all to plan view.
