Hi I would like to find a certain tag value of a block in paper space. The tag's name is always the same - in this case 'REV' but the blocks (title block) names can vary. Generally there is only one attributed block in paper space. (ie the title block).
I have had a look for something that might work but I can't find something suitable for what I want.
To sum up :
1) find attributed block that has a tag called 'REV' in paperspace
2) Find the value of the tag called 'REV'
thanks for your help
Hi
An example
(defun c:test(/ att bl sel)
 (vl-load-com)
 (and (ssget "x" (list (cons 0 "insert") (cons 66 1) (cons 67 1)))
     (vlax-for bl (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
   (foreach att (vlax-invoke bl 'getattributes)
     (and (eq (vla-get-tagstring att) "REV")
       (princ (strcat "\nBlock name " (vla-get-name bl) " with value " (vla-get-textstring att)))
     (vla-delete sel)
thanks a million Patrick - that's perfect! :D
I have taken it one step further by trying to find the revision letters in all the tabs.
I can not make the list not sure what mistake(s) I am making.
Can any point out what's wrong?
thanks
btw "dos_multilist" is a dos_lib function.
(defun c:RevLetter (/ layout_list RevLetterList RevLetter att bl sel LLN)
(setq layout_list (dos_multilist "Find revision letters" "Select tabs" (ListLayouts)))
(foreach LLN layout_list
   (ListLayouts)
(setvar "CTAB" LLN)
  (setq RevLetter (vla-get-textstring att))
    );foreach
     (vla-delete sel)
 );and
 (setq RevLetterList (append (list RevLetter)));make a list of rev letters
 );foreach
 );defun
(defun ListLayouts(/ oApp oDoc colLayouts LayList LayListSorted LayListWModel LayListinOrder)
     (setq oApp (vlax-get-acad-object))
     (setq oDoc (vla-get-activedocument oApp))
     (setq colLayouts (vla-get-layouts oDoc))
     (setq LayList nil)
     (vlax-for oLayout colLayouts
     (setq LayList (append Laylist (list (cons (vla-get-taborder oLayout) (vla-get-name oLayout)))))
     (setq LayListSorted (vl-sort LayList '(lambda (x y) (< (car x) (car y)))))
     (vlax-release-object colLayouts)
     (vlax-release-object oDoc)
     (vlax-release-object oApp)
     (setq LayListWModel (mapcar '(lambda (x) (cdr x)) LayListSorted));Layout list with model tab
     (setq LayListinOrder (cdr LayListWModel));Layout list without model tab
     LayListinOrder
Hi
Try this
(defun c:RevLetter (/ layout_list RevLetterList RevLetter att bl sel LLN str)
   (if str
     (setq str (strcat str "," LLN))
     (setq str LLN)
; (ListLayouts)
;(setvar "CTAB" LLN)
;(and (ssget "x" (list (cons 0 "insert") (cons 66 1) (cons 67 1)))
 (and (ssget "x" (list (cons 0 "insert") (cons 66 1) (cons 410 str)))
           (setq RevLetterList (cons (vla-get-textstring att) RevLetterList))
;           (setq RevLetter (vla-get-textstring att))
       );foreach
     (vla-delete sel)
 );and
;  (setq RevLetterList (append (list RevLetter)));make a list of rev letters
  (setq RevLetterList (reverse RevLetterList))
;  );foreach
);defun
     (setq LayList nil)
     LayListinOrder
My list of layouts in order
(defun ListLayouts(/ lay liste_lay lst n)
 (vlax-for lay (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
   (setq lst (cons (cons (vla-get-taborder lay) lay) lst))
 (setq n 1)
 (while (assoc n lst)
   (setq liste_lay (cons (vla-get-name (cdr (assoc n lst))) liste_lay)
         n (1+ n)
 (reverse liste_lay)
mercey! Patrick that works great!
