apsonwane Posted July 22, 2009 Posted July 22, 2009 Hi, When you are in layout tab, is it possible to Activate next Layout (in multiple layout drawing) from command line instead of clicking on next layout tab. Tnx, Quote
ReMark Posted July 22, 2009 Posted July 22, 2009 Wild guess here. Would it be the system variable CTAB? Quote
apsonwane Posted July 22, 2009 Author Posted July 22, 2009 Wild guess here. Would it be the system variable CTAB? Thanks ReMark, "CTAB" returns the name of current active tab. I would like to activate next layout tab without entering next layout name. Quote
ReMark Posted July 22, 2009 Posted July 22, 2009 Without entering the layout name? OK. I'll poke around. Maybe a LISP routine would work here? Quote
bonehead411 Posted July 22, 2009 Posted July 22, 2009 Not command line input as such but Ctrl + Page Up / Down will cycle through layouts. Quote
Ashishs Posted July 22, 2009 Posted July 22, 2009 Not command line input as such but Ctrl + Page Up / Down will cycle through layouts. Tnx bonehead411, This was new for me & serves purpose. However to make is more handy, is it possible to modify CUI or create a lsp routine so that when I input "NL" on command line to activate next layout. Quote
ronjonp Posted July 22, 2009 Posted July 22, 2009 Give this a whirl: (defun c:nl () (setvar 'ctab (cadr (member (getvar 'ctab) (layoutlist))))) Quote
NBC Posted July 22, 2009 Posted July 22, 2009 Cool ron; is it possible to modify that so that it will move to the previous layout ? Quote
Ashishs Posted July 22, 2009 Posted July 22, 2009 Give this a whirl: (defun c:nl () (setvar 'ctab (cadr (member (getvar 'ctab) (layoutlist))))) Thanks "ron" from prompt answer. This is what I was looking for. Simple & Perfect. Tnx all, Quote
apsonwane Posted July 22, 2009 Author Posted July 22, 2009 Dear Ron, Works in layouts. But doesn't work when model space is active. Command: NL ; error: AutoCAD variable setting rejected: CTAB nil Quote
ronjonp Posted July 22, 2009 Posted July 22, 2009 This one should work as advertised (defun c:nl (/ lay next) (vl-load-com) (vlax-map-collection (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) '(lambda (x) (setq lay (cons x lay))) ) (if (setq next (cadr (member (getvar 'ctab) (mapcar 'vla-get-name (vl-sort lay '(lambda (x y) (< (vla-get-taborder x) (vla-get-taborder y)))) ) ) ) ) (setvar 'ctab next) (setvar 'ctab "Model") ) (princ) ) Quote
NBC Posted July 22, 2009 Posted July 22, 2009 not forgetting to include (vl-load-com) immediately after the line beginning defun.... and immediately before the line beginning (vla-get-layouts..... Quote
apsonwane Posted July 23, 2009 Author Posted July 23, 2009 Thanks ron, This is flawless now. I found similar program here for activating first, next, previous & last layouts. I would like to share this with you- http://www.cadtutor.net/forum/showthread.php?t=36727 Tnx, Quote
